Question about Monte Carlo (5LCR52MW) Fan
Monte Carlo fan light turns on and off randomly. Is there a way to fix this?
5 Suggested Answers
  • 579 Answers
SOURCE: Light on fan.
Most likely, the dimmer control has failed and needs replacing. Would be good to check its output voltage first.
Posted on Dec 31, 2007
  • 569 Answers
SOURCE: remote control wall unit does not turn on Monte
Are the manual switches on the fan in the 'on' position?
Select the maximum fan speed on the remote and then operate the manual switch on the fan. Set that to the highest speed then control it with the remote.
Same theory applies to the light.
If this is not the problem then the remote receiver on the fan is probably faulty.
Posted on Feb 28, 2010
farmerbear
  • 490 Answers
SOURCE: The pull chain for the light on my Monte Carlo
Well, you can take it down and replace the switch. Most decent hardware stores have generic internal switches. You could unscrew the bulb a little every time you want it off.
You could mount a wall switch for the unit and live with the fan and light always being on at the same time.
The pull-switch is not too difficult to replace, just seems scary. disconnect the unit from all power and do the work at the table.
Keep all fasteners in order of removal, and make notes or label parts with tape as you disassemble. Take a picture of the switch when you get it open and show it to the person at the store. Bring home the new switch and swap it in one wire at a time.
Reassemble, remount, and sew on your DIY achievement patch:) Farmerbear at FixYa.com
Posted on Sep 30, 2010
Testimonial: "Thank you farmerbear. I will try to replace it myself. I'll update ya when I'm done."
  • 6 Answers
SOURCE: Where could I buy the
If you go to Monte carlo's website, www.montecarlofans.com, and in the upper right hand side of the screen there is a search bar. If you search for your model number you will realize that they discontinued that model of fan. They won't have a motor for a discontinued fan unless they use the same motor for another model fan (not likely), but I took the liberty to call and find out for sure. The answer is no, they are discontinued. Sorry, but looks like you need a new fan.
Posted on May 21, 2011
2001 monte carlo electric fan won't work. I changed the censor and the relays. How can i fix the problem ?
What Monte Carlo fan do you have? Are you replacing with correct parts? fanman9952@aol.com
Jul 26, 2014 | Dryers
I need the replacement glass dome for a Monte Carlo Mini 22 ceiling fan
I only see a Mini 20 in the Monte Carlo catalog & it doesn't come with a light. If it was bought at Lowes then you have to go there or call Monte Carlo @1-800-519-4092
Aug 07, 2013 | Dryers
I have a 2003 monte carlo ss and the turn signals flash at the same time
sounds like the light is blown this will affect the other lights change the burnt bulb it should fix it
Dec 31, 2012 | 2003 Chevrolet Monte Carlo
My new monte carlo fan comes on at night by itself. Sometimes the fan comes on. Sometimes the light comes on. Sometimes it comes on multiple times after we turn it off. We do not have a remote, just
MODEL NUMBER please so I/(we) can see how your fan is controlled? RF? IR? looong string? (Sorry ~ I could not resist).
Methinks FIXA NEEDS a new category of "FANS".
Anthony
Dec 23, 2017 | Monte Carlo Fans Dryers
Remote control wall unit does not turn on Monte Carlo fan or light although red light comes on when buttons are pushed (fan and light worked for about 2 years although it was hardly ever used).Frank
Feb 28, 2010 | Monte Carlo (5LCR52MW) Fan
Weak spark on a 1999 monte carlo 3.1L
i had a similar problem with my 99 monte 3.1 i replaced the coil wires and plugs then i looked at the fuel injectors and they were clogged causeing the car to throw codes about missfires, take a look at the injectors and try cleaning them
Jan 11, 2010 | 1999 Chevrolet Monte Carlo
2002 monte carlo overheating
Better make sure the fan works. There is a switch on the radiator that turns the fan on when it gets to a certain temperature. It could be the fan or the switch. Your thermostat is not your cap, it's in a different location. (Usually at the engine end of the upper radiator hose) Get the leak check! A good garage can pressure test the system to see what leaks you might have.
Sep 07, 2009 | 2002 Chevrolet Monte Carlo
Monte Carlo (5LCR52MW) Fan Logo
209 people viewed this question
Top Monte Carlo Dryers Experts
Craig Butler
Craig Butler
Rani wadia
Rani wadia
Tom Chichester
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
