Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Broke off the ice maker shut off arm. want to
Broke off the ice maker shut off arm. want to replace it
  • 10,865 Answers
Hi. Go to the site called sears parts direct. Enter the model number and see an excellent parts diagram. Order the part and u will have it in a couple of days. J.
Posted on Jul 30, 2010
Do you have to remove the screws on the ice-maker to remove the plastic icemaker service tray.
I believe you are talking about the shut off arm. You need to remove the lower freezer drawer. Pull it all the way forward and then lift up. The screws are under the icemaker.
Nov 01, 2014 | Sub-Zero 736TCI Refrigerator With Ice Box
Why won't the ice maker shut off even when I shut off the switch? The ice maker does not use a shut off arm or lever
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Sep 05, 2014 | Kenmore Refrigerators
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Samsung RF266AEPN
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
Oct 09, 2012 | U-Line Icemaker
Ice maker overfilling
OK i took a look at the ice maker. this has a shut off arm. i am guessing it always shut off automatically when you 1st had it right? but now it just makes too much ice. does it still do it if you lift the shut off arm up? if you lift it up and still makes to much ice then replace ice maker. (wait a couple of days)
if it stops making ice then just shut it off every other day thanks
Mar 28, 2010 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
How do I shut it off, going on a trip. Ice maker swing arm is broke, it just flops. Thanks
Without that swing arm, the only way you can turn the ice maker off is to remove it from the freezer, or of course replace a new swing arm.
I would also highly advise turning the water off to the refrigerator. this is good advice for anyone leaving their home for a while, whether or not you have a problem with your icemaker or water dispenser system.
Visit my website for service or to ask general refrigerator questions: www.FixMyFridge.net
Mar 17, 2010 | Amana ABB1927DE Bottom Freezer...
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
seabreezehvac@yahoo.com
Dec 18, 2008 | Amana ARB8057CSR Bottom Freezer...
Magic chef MCIM30TS table top ice maker shovel breaks
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Nov 21, 2008 | Eastern Tabletop 7002 Stainless Steel 24...
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
154 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
