Question about Weber SPIRIT E-210 (NG)
The grill seems to get no gas. The guage shows the tanks as empty even though they are not entry. The grill will not light, but no gas seems to be emitted. Weber Spirit
  • 10,865 Answers
Hi. Your problem has to do with the newer tank technology safety valve. Do this. Turn off the tank and disconnect it from the gas supply line. Then reconnect it and S-l-o-w-l-y turn on the valve. This should solve your problem. From now on always turn the valve slowly. J.
Posted on Jul 30, 2010
How come my gas gauge dont work right,full all the time even when there is no gas in the tank, dont like to run out of gas
Make sure dash guage is working,,," moves when key is turned on,,,,The sending unit in the tank is bad or has came disconnected,,,it will need replaced,,, if it shows full bad sending unit,,, if it shows empty the ground wire is off or damaged,,,,,unless the guage in the dash is bad,,, chevy has had a world of problems with there dashes,,i would think its the dash guage
Mar 03, 2015 | 2001 Chevrolet Blazer
2001 JEEP GRAND CHEROKEE
yes it may be ur computer problem
try to off it for few hours and then ON it
May 16, 2008 | 2001 Jeep Grand Cherokee
Fuel guage always shows empty
It sounds as if the fuel tank sending unit is faulty. This is a small float connected to a variable resistor on the fuel pump/sending unit assembly. Unfortunately this assembly is fairly expensive (over $300) and the fuel tank may need to be removed to replace it.
Aug 23, 2012 | 1999 Isuzu Rodeo
I have a Hyundai Elantra 2001. The low fuel light came on and won't go off even though the car if full of gas.
If gauge still shows empty and light is on then inside tank there is a arm thats prob just stuck remove lower rear seat and will see entry to tank gauge has about 3 to 4 screws open and check if arm is down or floating .
Mar 19, 2012 | 2001 Hyundai Elantra
My gas guage stays on empty and the tank is full
Sounds like your senor in the gas tank it self is bad. Most cars have a float that read out how full the tank is and when it goes out it will stay stuck showing you on the dash that your tank is empty even though it is full.
Nov 03, 2010 | 2000 Buick LeSabre
This si the second time I have had a problem when I changed tanks. It started working the first time but not this time. The tank valve is open and the pressure guage is in the green, until you tirn on...
Many newer grills have a safety feature built in where the valve will not
allow gas to flow if the burner valve is in ON position when the valve on
the tank is opened.
Try this - Shut of all valves, disconnect and then re-connect hose to tank,
turn on valve above LP tank, THEN turn on burner valve, light w/ spark or
match...
This feature can be really frustrating if you don't know it is in
operation...
Sep 06, 2010 | Brinkmann Charmglow Stainless Steel LP...
No Gas Getting to Back Burners
sounds like you have debris in the gas regulator,remove the tank and look into hose end to see lf its clear.sometimes just tapping lightly on the reg,will release the debris.u may need to replace hose and regulator to burner assymbly.if this doesnt fix it.
Apr 13, 2010 | Weber Genesis Silver C Grill
1987 fuel level guage issue 87 F150 Lariat XLT 5.0 2wd. Have a very similar situation. Front tank position shows empty even when I know there is gas. Rear tank position shows full after refilling but...
the gas is regulated from the switching valve you control off the dash. Check the valve to hear it switch
have a friend help you do this. it will be located under the truck between the two tanks. You may have a faultly valve or switch rattling inside changing the tanks setting also while driving which will be hard to tell
Jan 31, 2010 | 1987 Ford F 150
Gas guage on 2006 nissan pathfinder
Try to check the guage sensor in your tank maybe the contacts need to be checked or may be needs to be replaced...
Jun 29, 2009 | 2006 Nissan Pathfinder
Weber SPIRIT E-210 (NG) Logo
152 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
