Question about Maytag MDE308DAYW Electric Dryer
My dryer worked perfectly but after our basement flooded and the bottom.of the dryer got wet, it runs but doesn't heat up
    President:
  • 3,773 Answers
Check element and thermal fuse
Posted on Jul 30, 2010
Hello, my dryer got wet due to my basement flooding and it starts, but no heat.
It is highly risky to use any electric appliance even after the removal of flood water. Before using it you need to make sure that it is not wet from either inside or outside. Even a single drop of water can cause a short circuit at you home and can also lead to unfortunate event. In such case you need to search for a company like http://floodfixer.com/ that dries wet basements to ensure your safety. Professionals can bring your valuable possessions back to its original position and make them ready for reuse.
Sep 12, 2011 | Hotpoint NBXR333GGWW Gas Dryer
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
4 month old admiral dryer. Basement got flooded. Very little water hit bottom of dryer. It tumbles but has no heat. What do I do?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Dryers
Basement flooded,Dryer runs but wont heat
heatman101
Jul 26, 2011 | Frigidaire GLGR341AS Gas Dryer
My basement flooded and now my dryer won't start..What should I do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor got wet and is no good anymore...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2010 | Kenmore 500 6953 Dryer
I have a kenmore front loader dryer. My basement recently had a flood and the bottom of the dryer was wet. When i tried to start it, it hums but will not run. What is the problem?
the motor is cooked,i live in the boston area and we had some bad floods a few months ago,all i did for two weeks was change out dryer motors,you can try to spin the drum and hold in the door switch and have someone else hold in the start button to see if it will start but you have to change out the dryer or get a new one if it's in rough shape
Aug 05, 2010 | Kenmore 73952 Gas Dryer
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Dryer won't run.
First, there is an excellent chance you have some kind of flood damage insurance.  It may pay for part of the repair.  You did not tell us what is not working but I'll guess it is the motor.  On many models, there is a switch on the motor which will not allow the elements to heat unless the motor is powered and running.
Dec 19, 2008 | Kenmore 63942 Dryer
Maytag MDE308DAYW Electric Dryer Logo
99 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
