Question about Frigidaire Refrigerators
On a side by side refrigerator/freezer cellanoids are not releasing water. I am in a rental a friend has tried getting the water/ice dispenser to work. New water line has been installed, cellanoids seem to be operating but water is not getting to ice maker or water dispenser. The screen at the water inlet has been cleaned.
HVACRH20
  • 237 Answers
SOURCE: Whirpool Side by Side Ice Dispenser Freezes up
Think you have it figured out. Just had a similar problem. The flap leaked air (moisture) up into the area which then froze. Then the customer chipped it out with a knife and not only damaged the flap seal worse but also made the chute area rough from the knife tip "burrs" in the plastic chute. A new flap door with factory seal along with sanding down the burrs cured the problem. Spraying something food grade like Pam cooking spray (very lightly) will aid in the ice cube/crushed ice to slide down the chute better. With any refer, keep the moisture out or it WILL freeze up stuff.
Posted on Nov 09, 2006
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
SOURCE: Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Posted on Apr 10, 2009
Ice maker quit making ice how to find problem
Good Morning Friend,
I understand that your Frigidaire refrigerator, model# FRS26R4A, stopped making ice. Here are a couple of suggestions you may try, to get your ice maker to produce ice.
    1)Make sure that the wire signal arm, inside the bucket area, is in the down or ON position.
    2)Make sure your household water line valve is open and on.
    3)Make sure your freezer is cold enough.
    4)Make sure the water dispenser is dispensing water. If not, the ice & water filter cartridge is clogged or restricted by foreign material, and must be replaced.
    I hope this is helpful.
    -Best Regards-
    WP
May 22, 2014 | Frigidaire FRS26R4A Side by Side...
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Kenmore side by side model 106.5xx. The ice bucket has ice but the dispenser on the door will not release the ice. I hear a click but nothing happens. I removed all of the ice from the bucket and the...
The freezer part is working but the refrigerator part is leaking water from the left side upper corner .there is like a vent from, where the water is leaking and the refrigerator side is not cooling any hint or advice will be appreciated thanks
Sep 19, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can't get Ice/Water to dispense, I hooked-up the water hose from the water source to the refrigerator, turned-on the water, left the freezer bar in the "On" position, and unlocked the dispense. I verifed...
If this is a new purchase, you will have to depress the water dispenser lever long enough for the water to make it all the way through the system, including the water tank located inside the fresh food compartment.
Aug 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
Stuck water valve/switch on freezer door for dispensing water/ice
remove covers, possibly use a drop of 3in1 oil onto the switch and run the switch through a few cycles, if that doesn't unstick it then you will need to replace the switch
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
27 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
