Question about HP LaserJet P2015n Printer
Hi i have a hp laser jet p2015n, error lights
Hi i have a hp laser jet p2015n, when i turn on my printer the Go, Ready, and Attention lights are on and i cannot print at all. I have a working p2015n and i tried replacing all the major parts like formatter board, dc board , fuser assembly, and even the solenoid ing the tray 2.I'm i forgetting something? can u help me. thank you.
  • 52 Answers
While all lights lit press go button and check secondary light pattern probably scanner if you have tried all parts listed
Posted on Jul 30, 2010
  • skelter0 Aug 04, 2010
    i already did that nothing happens. and i also tried replacing the scanner.. the only parts that i haven't moved is the paper censor in tray 1 and the other 3 censor under the pick-up roller in tray 1. could it be possible that one of this censor is defective? what is the error you will get if have a busted censor? can u help me.. thank you have a nice day.
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
HP M2727 printer has FLASHING attention and ready lights
leave printer on, and unplug the power supply, then wait10 min. plug it back in, this should reset the printer, you might have to do this again and unplug any connections to your computer, wait and then plug in printer with power off and plug in connection to your computer, then turn on printer,, check your ink levels when you power up. if ink levels are low ,you could get this error. if this don;t work go to your printers website and check there solutions or you might have to call them.
Oct 02, 2012 | HP CB532A - LaserJet M2727NF All-in-One...
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    My HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on
    Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
    Sep 29, 2011 | HP LaserJet 4250n Printer
    Code ereur 59
    A code error 59:
    Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
    1. Press the green c00099346.jpg (Select) button to continue.
      3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
      4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
      6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
      7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Mar 02, 2011 | HP LaserJet 5550DN Printer
    I have P2015n laser jet network printer. Since last two days garbage printing is contineously going on how to reset or stop this printing. Pl. give solution. Nitin Joshi adminnsk@ksb.co.in
    1, Go to your services and restart Print spooler (start-run-services.msc) start stop it 2. Reinstall printer driver 3. Check your network or USB cable (depends how you have conected it)
    Best regards
    Mar 01, 2011 | HP LaserJet P2015n Printer
    When the printer is booting it is stuck at **************************, when it do comes on it comes with error code Error 49.4c02 Product model: HP Laserjet 4100N
    Thank you for contacting FixYa with your printer inquiry.
    HP Laser Jet 4100 49.4C02 Error
    49.xxxx PRINTER ERROR
    Description 49 errors are generally communication errors or file related issues and can usually be resolved by following the steps below:
    Action Turn the printer off, and then turn it on again.
    If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card (or any third-party devices), if installed.
    Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
    Turn the printer on. If the 49 error returns, turn the power off, and then unplug the printer. Remove the formatter board.
    Check that the parallel I/O board is firmly installed on the formatter board.
    Check for any non-HP memory DIMMs. If any extra memory is installed, remove it.
    Reconnect the power cord, and turn the power on.
    If the 49 error returns, perform a cold reset.
    Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    Press (Select). The printer will perform a cold reset and then continue its power-on sequence. If the error code continues to come back, it requires a firmware upgrade.
    If the 49 error returns, contact an HP-authorized service or support provider.
    Hope this helps helps. Please keep us updated and remember to rate this answer.
    TF
    Jan 05, 2011 | HP LaserJet 4350 Printer
    HP 5500 can not print with 59.CK error code on display
    You probally need to contact an engineer on this one, from HP trouble shooting manual
    Description
    Action
    1. Press the green <Tick Symbol>(Select) button to continue.
    a. Turn the printer on.
    b. Watch the control panel.
    c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
    d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    f. Press (Down Arrow) button once. The control panel will display COLD RESET.
    g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Sep 22, 2009 | HP LaserJet 5500 Printer
    Fetal error on HP laser jet 1160
    Hi naseeh83: Here your problem. Fuser error. The fuser has a malfunction. Try these steps. 1. Unplug the printer for at least ten minutes. 2. Verify that the fuser connector and thermistor connector are both firmly seated in the ECU 3. Perform a heating element resistance check. 4. If the resistance readings are correct, but the error persists, replace the fuser. You may have to call a certified HP technician to repair this printer. Hope this helps.
    Jun 10, 2009 | HP LaserJet 1160 Printer
    A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
    Reference via HP Website, Click Here
    To Fix the problem:
    1. Press the green c00224695.jpg (Select) button to continue.
    2. Turn the printer off, and turn it on again.
    3. Perform a cold reset.
    4. If this message persists, contact an HP-authorized service or support provider.
    Mar 21, 2009 | HP LaserJet 4600 Printer
    HP LaserJet P2015n Printer Logo
    156 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
