Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Hi, I have an LXi heaterthat keeps kicking off! On
Hi, I have an LXi heater that keeps kicking off!
On the field wire board the red light blinks three times in a row then a pause then three more blinks and so on.
    Scholar:
  • 78 Answers
This usually indicates an ignition lockout...The heater tried to fire but either didn't fire or a flame was not detected. Check and ,ake sure ignition is good, gas valve is opening and make sure all grounding is intact..
Posted on Aug 01, 2010
My dishwasher ( quiet partner I)has a blinking clean light it blinks 7 times indicating an error. I tried reseting it but that didn't work.
next time send the brand name and model number,from what i've seen if that light flashes 7 times you either have a bad heater or a bad computer board,you can remove the top panel with the power off,then remove the bottom panel you'll see a tech sheet there that will tell you about the error codes,you'll also see a diagram you can read the heater from the wires,depending on your model if you look at the board i think there's a red and white wire and a blue and red wire,pull the wires off and with your meter you can check the heater or pull the dish washer out,remove the wires on the heater and read the heater out there,whatever is easier for you,also on some models you'll have to look at the diagram you read it out from one wire on the door switch and the other of of the board but like i say you have to look at diagram to see what wires,if the element reads good set on continuity then you have a bad computer board. good luck
Nov 14, 2017 | Dishwashers
Goodman gmh95 furnace wont ignite
try the pressure switch you may be able to jump it out and see if it lights
Oct 01, 2016 | Goodman Heating & Cooling
RV FURNACE
It's hard to answer your question without the age and brand of your heater but the blinking of the red light can be a heartbeat, which indicates all systems are ok and there is power or the blinking is like 2 blinks, pause, and 2 blinks, pause repeating. That would indicate a failure code. In that case Google the model and serial number to get the failure code.
Oct 26, 2014 | Heating & Cooling
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
The heater won't light up on my Jandy LXi400n Lxi heater
make sure red light is on for calling for heat if so make sure 24 volts ac on both sides of pressure switch if ok make sure gas is on
Jul 13, 2012 | Jandy LXI400N Lxi Pool & Spa Heater -...
Normal light flashes, unable to operate
Hello.
The reason the ligh keeps blinking is because it is displaying a error code. How many times in a row does the light flash before it pauses and blinks again?? the number of times it blinks in a row is the number of the error code its displaying...example if it blinks 7 times in a row before a brief pause its is displaying the E7 code and so on.
This tip i wrote will tell ya how to reset the control board but be sure to reply with the amount of times it blinks and i will let ya know whats its telling ya.
Here is that tip to reset it http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 24, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My furnace the burners light and come on and heat up the unit. But the fan never kicks on and blows. The fan itself works because I can turn it on manually so I know it's not that. The trouble code...
The manual selection on the thermostat bypasses the fan relay. When in Auto, the fan relay turns on the blower. You are probably looking at replacing the circuit board. As far as the three blinks, on the reverse side of the front panel there is a wiring diagram and error code chart. It will give you a starting point where to look for a problem. The three blinks could indicate an open limit because the blower is not operating. Keep the blower on manual and let the furnace run normally until you can figure out what the problem is.
Feb 23, 2011 | Intertherm Heating & Cooling
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
792 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
