This long thin plastic ribbon has fallen off from somewhere inside the printer and i cant seem to get it back on. There is two hooks one on each end but I can't make it fit from one to the other. How exactly does it go on? It is on a Lexmark x2470 all in one printer.
  • 906 Answers
Good day Sir, click the link below and download your printer's manual.
Printers manual
have a nice day.
Posted on Jul 30, 2010
Cannon Pixma printer plastic with two spings at each end that moves the printer carriage snaped(spring at one end but the spring for the other end is somewhere in the printer) What do I do? Printer is only...
Try turning the printer upside down and rocking it back and forth to see if you can tip the original spring out. If you can't locate it or hear it rattling around inside, find a replacement spring at the hardware store and hope the spring flew out of the printer when it broke.
If it's a tension spring (hooked on each end), drill a small hole (probably #60-#54 drill size - choose the smallest size that will accommodate the spring wire) in the remaining plastic, and hook it up on this end. Reinforce the area around the new hole with the spring in it with a couple of thin layers of epoxy before connecting the other end of the spring.
Feb 13, 2011 | Canon Office Equipment & Supplies
A plastic strip seems to have out fallen; its the
If it's the transparent strip that fell off from the assembly, it's called the encoder strip. It is, somewhat, related to sending information to the carrier's movement on the carrier shaft or the silver rod accross the printer. I'm afraid that can't easily be fixed. But, it would be better to contact Lexmark for assistance. They may be able to help you with that. Hope I can help more on this.
Mar 22, 2010 | Lexmark X5495 Printer
I have a dell V305 Printer and there is a plastic strip that has fallen off from somewhere inside. Can you advise as to what this strip is for and if it can be reinstered?
If it's a clear plastic with black lines on it, it's the encoder strip. If the holes on the end are not torn out, it installs inside from the right side to the left side, one side has a spring to connect to and the other side has a solid hook on the frame. It has to thread thru a sensor slot at the rear of the carriage assembly in order to work.
Jan 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
My printer cartridge jammed. I pulled on it and disconnected a thin strip of flim that pulls the cartridger to print back and forth. How do I replace it
Is it broken OR is there a little hook on the end of the ribbon?
A broken ribbon will probably have a jagged or stretched end.
If it is a hook of sume type, there will be a matching hook under the carriage.
IKf it is broken, you probably have a new door stop.
Sep 25, 2009 | Lexmark X2500 All-In-One Printer
Plastic ribbon has fallen from my printer
It seems some part is broken inside, better to send it for repair.
Apr 21, 2009 | Lexmark X2470 All-In-One InkJet Printer
A thin ribbon made from plastic fell out of printer, where does it go? Printer model:2400 all-in-one. part 1/4inch by 12 inches appr.
have a look at the ends of the ribbon to see if any of the connections are exposed, they will look like brass or gold, if they are you may possibly be able to put is back in place. the ribbon goes in the ink carrage at the right of the printer (the unit that slides up and down to print accross a page) and is also connected to the left or right hand side of the printer, this is all internal and you have to take the printer apart
If the plastic coating covers the whole ribbon cable, or just at one end, this means the ribbon cable has snapped and you will probably have to buy a new printer
good luck
regards
Nov 18, 2008 | Computers & Internet
IDE ribbon pulled out!
The "IDE" cable you refer to is the "Flat Flexible Cable" or FFC in Epson parlance. It connects to the Main Board. To remove the top cover, apart from the obvious fixings at the back, you need to release the two hidden hooks at the front of the cover. For this you will need a strong thin strip of metal - an old fashioned ladies nail file is ideal, or a very thin screwdriver might do; it also takes a bit of a knack to do this, so be patient. You will need to lay the printer on its back, but note that in this position, waste ink can spill out of it. Make sure you lay it on a good thick layer of newspaper. Underneath at the front near each corner you will see a narrow slot.
Insert the metal strip in one, at an angle such that you touch the front wall of the case. Slide the tip of the strip up the case wall until you feel an obstruction - this is the hook. GENTLY prise the hook away from the wall and the case will open a bit; do not use too much force or you will break the hook - it is only thin plastic.
Repeat the process the other side. Complete the case removal by GENTLY pushing in the hooks at the back. When you replug the FFC into the main board, make sure you thread it correctly around the guide posts, so that it can move backwards and forwards correctly when the print head is moving. Test the printer before you put the top case back on. You may feel it would be sensible to purchase a Service Manual before you tackle this task - they
are pretty cheap.
Oct 17, 2008 | Epson Stylus C48 InkJet Printer
Carrier jams to the left hard,when i turn it on
I don't know your printer so this may not be the problem.
Check inside with a flashlight and look for a plastic band laying in the wrong place; this is a clear ribbon with very fine vertical lines on it that the printer uses to 'count off' its position. Normally, a printer will go to one or the other end so it knows where to start counting to determine where it must go and identify its arrival at a particular character position as directed by the software sending the data.
These bands can break or become contaminated so it is no longer clear where the carriage is or where to go next.
If you find such a band and it is intact, clean it gently with glass cleaner and soft cloth or paper towel and reinstall it, threading it through the slot in the carriage where the optical path is located that 'reads' the stripes.
All printers using this type of technology will have one static hook for one end and a second that is a leaf spring with a hook for the other end of the band.
Sep 30, 2008 | Epson CX8400 All-In-One InkJet Printer
Plastic strip fell off
Hi, if you open the open the printer, unit to gain access to install ink cartridge, if you see the metallic end which has got a hook on both the ends left and right side. the ink cartridge runs between the strip from left to right which should be connected above the ink cartridge meta rod.
< ------------- >metal hooks on left and right above the cartridge rod
======= __ cartridge rod
Let me know for further info.
Feb 05, 2008 | Dell 810 All-In-One InkJet Printer
Loose Parts??
Sounds like the Encoder Strip, but without the Brand Printer and model number, I cant be 100% sure.
If it is the encoder strip, this is what the printer uses to tell where the carrriage is located at. Without it, the printer won't work.
You can try to repair but it will take a little time. 1st make sure that the encoder strip isn't torn at either ends where the spring goes in.
The encoder strip goes from 1 end to the other end, and it also goes through a small opening in the back of the carriage unit.
If you have a make and model, I could be a little more specific.
Good luck.
Feb 05, 2008 | Office Equipment & Supplies
37 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
