Question about AOC Computers & Internet
Estou com problema na placa lógica do monitor modelo tft 19w 80ps, nome do produto 913 fw. ele quebrou o conector da placa que liga o cabo lógico, portanto solicito alguem me dar uma dica de onde compro a dita placa. jorge borges
Benimur
  • 6966 Answers
SOURCE: Urgeunte samsung syncMaster 551v
Hi and welcome to FixYa,
Initially, pls try here for the wiring and schematics. The VGA pinouts may be referenced from here.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 10, 2008
  • 36 Answers
SOURCE: problema com o monitor samsung syncmaster 913N 19"
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Posted on May 15, 2009
Vaio Tech
  • 166 Answers
SOURCE: Lcd Asus VW193D NÃO LIGA
OLHA parece que o teu pc tem a power supply ( fonte de alimentacao ) queimada tenta uma outra fonte de alimentacao e o teu pc voltara ao normal obrigado e se tiveres mais problemas pergunta que eu ajudo-te outra vez obrigado
Posted on Nov 09, 2009
budmrtn
  • 11361 Answers
SOURCE: tenho um monitor 17s da
Please read here:
http://www.fixya.com/support/r4646147-philips_lcd_monitor_loc_unlock
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 18, 2010
bbl242003
  • 1637 Answers
SOURCE: hola. el prblema que tenia al principio con este
CERTIFICADO DE EXPERTOS AQUI TV, siga esta información que he proporcionado tres soluciones de largo a este tema / s
Solución 1
Antes de empezar a desmontar cosas, le permite probar su simple rutina retire el enchufe de alimentación y sistema de poder una copia de seguridad. También, por favor, intente su unidad en una canales diferentes para ver si el problema persiste en cada canal. Su principal del Consejo, Power Board, T-Consejo Regulador se sospecha que los problemas en este momento. Pulse y mantenga pulsado el botón de encendido durante unos 15 segundos, la unidad debe apagar por sí mismo después de haberlo encendido. Si no es así, entonces no te preocupes. Quiero saber si el problema persiste. El primer enlace a continuación le llevará directamente a la guía de solución de problemas si tiene que seguir adelante con el mismo error.http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Información adicional No se pudo TV y Monitores: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plaguepartes: www.shopjimmy.com
Le permite centrarse en la parte externa de la primera serie de televisión (95 por ciento de todos los problemas de la televisión están relacionados con cosas externas a la propia televisión) Compruebe la conexión física de todos los cables mediante la eliminación de cada cable pelado o RCA y volver a instalarlo (Cada cable de potenciaasí), una vez que haya quitado un cable, compruebe que no se deshilache, y si ya está desnudo, de empalme de una conexión nueva y fresca para ello. 5. Asegúrese de que NO hay otras radios uneeded, el sistema de las cercanías.estos sistemas, cuando se enciende, hará que la interferencia electromagnética y evitar que más que grave la interferencia de televisión SURGE PROTECTOR protectores contra sobretensiones representan más del 75 por ciento de las fallas eléctricas a los equipos de estéreo. Vamos a empezar con su toma de CA de pared. Es norma en América que 220 voltios de fuera de estos puntos de venta. Esto implica que cada dispositivo va a utilizar 220 voltios (dentro de esa zona de la red). En todo caso incluye un reloj de alarma está conectado a cualquier enchufe de salida de CA en las proximidades del equipo estéreo / TV, causará interrupción eléctrica, electrónica e impedir incluso de encender! El televisor necesidades dedicada energía eléctrica.Si el televisor se encuentra en la sala a continuación, desconecte todo lo demás en la sala de estar. Permite conectar el televisor a una toma de Dedicado. Revise todos los interruptores de luz para asegurarse que el poder es para el que toma. Compruebe el cable de TV para Desfibracion tanto en el extremo de la pared de CA y donde se conecta a la televisión.Compruebe todos los puntos de GFCI para garantizar que todos los botones rojo de reposición se empujan, compruebe los interruptores automáticos para la conexión adecuada y que están encendidos. Ahora, vamos a tratar el televisor sin que relacionada con cualquier servicio de cable, vídeo, dvd, equipo de música, etc Por favor, responda si hemos encontrado una solución.
Cuando la reparación de estas unidades, hay siempre varias variables a considerar. Primera visita para ver lo que ocurrió por última vez con la unidad, como hicieron los hijos juegan con videojuegos, ¿la electricidad salir debido al mal tiempo. Usted puede ver que hay muchas posibilidades, pero vamos a concentrarnos en lo que se produjo el pasado a la unidad. Una vez que determinemos lo ocurrido el pasado, podemos identificar la causa real del problema. La causa real puede estar asociada con problemas de proyección, las versiones anteriores (tubo de imagen), la interferencia de los dispositivos en las cercanías, e incluso una radio encendida y situada muy cerca de su unidad. Esto es normalmente conocido como interferencia electromagnética a la electrónica y es muy común el error que usted ha proporcionado hoy. Por favor, seguir buscando algo externo a la unidad antes de ver los componentes internos. He estado trabajando en estas mucho tiempo así que siéntete libre de seguir conmigo.
Posted on Jan 24, 2011
1999 Honda CBR 1100 XX Super blackbird sem fa?sca
Oi, Eduardo e os suspeitos habituais s?o:
1. Velas de igni??o embebidas.
2. Severamente descarregado ou uma bateria danificada deve ter 12,5 volts ou mais e poder passar um test "LOAD" adequado, se necess?rio, voc? pode ter uma leitura preliminar de 12,5 volts ou mais, mas pouco ou zero, a bateria est? com defeito e deve ser substitu?do, as baterias AGM falham neste cen?rio mais do que as baterias de chumbo-?cido.
3. Verifique os terminais da bateria para danos ou corros?o, verifique se os cabos da bateria est?o "AMBOS" para conectores soltos, corro?dos ou quebrados, "INSIDE" e fora do chicote de fios, execute o test de mecha do conector e verifique os cabos com um ohm?metro, se necess?rio.
4. Conex?o solta na bobina de igni??o ou conex?o entre o sensor de igni??o e o m?dulo.
5. Cabos da vela de igni??o em mau estado, curto-circuito / vazamento, conex?es do cabo da vela de igni??o verifique a vaz?o da centelha no escuro.
6. Bobina de igni??o ou m?dulo de controle eletr?nico defeituoso. 7. Bobina de pulso com defeito.
8. Sensor defeituoso CKP, CMP ou BAS.
9. Interruptor de igni??o defeituoso.
10. Comutador de marcha / desligamento defeituoso
11. O sensor de inclina??o precisa de uma reinicializa??o.
12. O alarme de seguran?a ao desarmar precisa ser redefinido Para obter mais informa??es sobre o seu problema e downloads valiosos "GR?TIS" que voc? precisar? para visualizar ou imprimir, clique nos links azuis abaixo. Boa sorte e tenha um dia maravilhoso. 99 blackbird no spark
How to diagnose no spark situation on motorcycle
1999 2002 CBR1100XX Super Blackbird Repair Manual Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda 1998 CBR1100XX Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 05, 2012 | 1999 Honda CBR 1100 XX Super blackbird
Tip
Preciso do manual da placa soyo SY-6IWM/L
Estou precisando do manual da placa mãe Soyo SY-6IWM/L.
Estou com problema no Setup. Não está abilitando o Som Onboard . Não sei se existe algum Jumper na placa para poder abilitar. No Setup aparece som Omboard, mas está desabilitado. Mas não há como eu abilitar, pois está com a tarja e o cursor não passa por esse item. Se alguem tiver um geitinho brasileiro, por favor me oriente nesta questão.
Grato;
RonyBueno
on Oct 21, 2008 | Soyo Slot 1 SY-6IWM/L Motherboard
Sc 335 da Ricoh 1075, como solucionar?
Olá!
Esse erro está relacionado com o Motor Poligonal do Laser.
Antes de mais deves actualizar o firmware da maquina. Existe uma referência que corrige esse sintoma.
Se depois da actualização o problema persistir poderá ser 1 destes problemas (por ordem de solução):
1-Mau contacto nos cabos do Motor Poligonal.
2-Motor Poligonal avariado.
3-Placa IPU avariada.
Espero ter ajudado.
See you!!!
Apr 01, 2011 | Ricoh Office Equipment & Supplies
Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Dec 31, 2010 | Kodak EasyShare V610 Digital Camera
Mi impresora canon mp150 prsenta error 6500 y no encuentro solucion agradeszco su opinion
Un error 6500 hace referencia a un error de la placa l?gica en la impresora. Con el fin de solucionar el problema, le recomiendo lo siguiente:
1. desench?felo y desconecte la impresora del equipo. desenchufar la impresora de la toma de corriente.
2. Pulse y mantenga presionado el bot?n "On" durante 30 segundos, luego deje la impresora solo por 10 minutos. Esto permitir? que alll corriente el?ctrica para ser dado de alta de la impresora.
3. conectar todo de nuevo a la computadora y toma de corriente. Encienda la impresora.
4. eliminar los dep?sitos de tinta de la impresora, a continuaci?n, volver a asiento. Aseg?rese de escuchar cada "clic" en su lugar a medida que los puso pulg
5. Apague la impresora y, a continuaci?n, de nuevo, prueba para ver si funciona ahora.
Si no es as?, tendr?s que ponerte en contacto con Canon para la reparaci?n de la impresora / una junta nueva l?gica para la impresora.
Dec 28, 2010 | Canon PIXMA MP150 All-In-One InkJet...
El problema que tengo es con una dell 3100cn y elo que me aparece en la pantalla es el siguiente mensaje "bandeja 1 debe de ser de 250 hojas" no me permite meterme al menu ni tampoco se queda...
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2010 | Dell 3100cn Laser Printer
Nov 09, 2009 | Computers & Internet
Code Security
code segurity its prodlema
Aug 06, 2008 | Panasonic CQ-VD7001U Car DVD Player
Problemas com o code L1
the problem will be found in the movement of optical system and the carriage that hold it-the sensor that pass by it.-drive mechanism(wire-belt)which responsible of carriage movement.last printed circuit-or i/o board connected to this part.
Feb 28, 2008 | Sharp AL-1642CS Copier
Drive terminators
Translate from portuguese to english... Meu HD também estava com este problema, o que fiz foi limpar o contato que liga a placa lógica do HD ao leitor do disco rígido que estava oxidado. O problema ficou resolvido.
Dec 27, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Computers & Internet Logo
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
