Question about General Electric GDWT260RSS Stainless Steel Builtin Dishwasher
My brand new GE GDWT260R10SS won't get the dishes dry even when I have "Added Heat" selected. Any help appreciated!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you have already selected “Added Heat” and it still wont dry dishes the issue seems to be with the heating element however, as it’s a new dishwasher so its always better to use the warranty to avoid any further issues. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 30, 2010
  • 3 more comments
  • ejmyer Jul 30, 2010
    Do you have a database that shows any issues with this model not drying dishes properly?
  • Rylee Smith
    Rylee Smith Jul 30, 2010
    Nope, the model no# was not found in my database so I provided you with the information from what you described in your post.
    Maybe I had the wrong model number, try GDWT260R. Don't give up on me yet...Pls
    hey, where did ya go??
  • Rylee Smith
    Check the water
    temperature inside the dishwasher to measure the water temp. It should be as
    close to 125 degree F to 140 degree F as possible. This would have happened as
    the dishwasher was overloaded with more than prescribed number of dishes. If still it is not resolved then the issue is with the heating element, and the model no# is still not correct.
#FDB1500LFB2 does not dry dishes after sanitize
Hey friend, I appreciate your post!
From my understanding your Frigidaire dishwasher, FDB1500LFB2, is not drying dishes after the sanitize cycle. Check to make sure the heat dry option has been selected on your dishwasher panel. I would also check to make sure that the rinse aid dispenser has been filled.
Assure that the temperature going into your dishwasher is 120 degrees, which you can verify by using the sink closest to your dishwasher. If all of that checks out I would suggest seeking assistance from a professional for further diagnosis and repair. I hope this is helpful. -Matt
Oct 08, 2014 | Frigidaire Dishwashers
Ge gdwt260r10ss won't drain
Probably one of two different things can cause this problem. Your dishwaser drain could be clogged you can take off the the drain and try to see if it is clear by using a vaccum cleaner reversed to try and blow air through the drain if clogged the air will be strickly hammpered or not getting through at all, if this is your problem then starting at the filtered drain and work your way to where the drain enters the house hold sewer. The blockage will some where between these points. The other possiblity is that the drainiagepump on the dishwasher is bad, you'll have to referre to your owners manual in order to see what it say about testing or replacing the pump. Hope this helps.
Aug 28, 2012 | GE Dishwashers
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
After i was my dishes they are still wet when finished
Make certain that you have selected "heat" for drying (if available on your dishwasher). If no such selection is available, try using "Jet Dry" that should assist with the water being removed from the dishes, glasses, etc. Some customers elect to open the door to "air dry", but all dishwashers typically have a "heat element" located at the bottom of the tub that dries the dishes, etc.
Feb 20, 2010 | Dishwashers
My dishwasher doesn't seem to be letting the jet dry out to the dishes. The silverware and the glasses seem dull and spotty and when I checked the jet dry it is still completely full. I haven't added any...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Dec 26, 2009 | GE Nautilus 24" Built-in Dishwasher
My brand new dishwasher leaves white film
The new washer is drying the dishes faster that the old one,Try setting it to no heat dry and see if that helps,if so you will need a water softener or filter for the water line to the washer.
Jul 29, 2009 | Dishwashers
Washer < 1 year old. Jet dry will not go in
as ur machine is still under warrenty u should go in touch with GE and have thos problem solved free of charge....
Mar 15, 2009 | GE Monogram® ZBD6880NSS Stainless Steel...
My bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Dec 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
General Electric GDWT260RSS Stainless Steel Builtin Dishwasher Logo
446 people viewed this question
Top General Electric Dishwashers Experts
Tom
gbob59
Marvin
Marvin
Are you a General Electric Dishwasher Expert? Answer questions, earn points and help others
