Question about Kitchen Ranges
Hi, I have a Matsushita GMX-8PV017A DC motor. It has several color coded wires and I don't have a wiring diagram. Can you possibly help me with info about this motor? Voltage requirement? RPM? What are all the wires for? Thanks, Dave
SOURCE: need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
Posted on Jul 28, 2008
SOURCE: Wiring Diagram required
who has a diagram of marantz sr-73 mkii?pls give me a picture of that,thanks!
Posted on Oct 31, 2008
  • 373 Answers
SOURCE: Ford Focus ST 2006 wiring diagrams & workshop info
can you check with parts department at ford and see if thy can
otherwisw check with autozone
Posted on Jan 31, 2009
SOURCE: STEREO WIRE CODES DIAGRAM FO A 1998 BUICK CENTURY
need codes to hook up radio to 1999 buick century
Posted on Mar 07, 2009
  • 116 Answers
SOURCE: Need low voltage wiring diagram for condenser
look on the indoor unit and see what they do you hav common from trans former yellow for compressor white for elect heat then reversing valve usually orange green for fan on the out door unit board you can tell what is common and what is for heat
Posted on May 09, 2009
Color coded wiring diagram 1995 gmc sierra electric windows
Google the
wiring diagram 1995 gmc sierra electric windows I found several systems offering what you require.
But what is the problem, 99% of the time in that year the window regulator was at fault, it was made from a stapped steel housing verses an cast unit. We check the left switch for power, disconnect the two wire connector at the motor, and see if the motor has power to one side or the other in the connector. If the switch has power to it, and the motor has power to it as you press the button, the motor is at fault.
Good luck.
Mar 16, 2015 | GMC Cars & Trucks
I need a wiring diagram for a 1959 Ford F-100 pickup truck?
A wiring diaghram for a 53 year od vehicle...simplicity itself! Check your local library for old car repair manuals. There are many out there-Chiltons, Motors, Mitchells, possibly even Haynes. I don't recall how good the wiring diagrams in those multiple car manuals are, but they might help you.
Another possibility is to join a forum for old ford truck enthusiasts. Just do a little searching on Google-I'm sure you will find several sites devoted to restoring old Fords and working on them. The people on the forums should be able to help you.
Good luck.
Mar 26, 2012 | 1981 Ford F 100
I need Only color coding for wiring diagram for cdx-gt550
If you are planning to install your radio, I recommend you purchase a wiring harness specific for your vehicle. All aftermarket radios are standardized in wiring colors. The harness will have the diagram to hook your radio to the harness. The problem with hardwiring a radio is the wiring colors don't match, and hooking it up wrong could fry your entire electrical system. You can find a harness at www.crutchfield.com Hope this helps.
Aug 23, 2011 | Car Audio & Video
Need wire diagram for 4 wire cord [color code[
Here is a tip that will help you with that problem...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 17, 2010 | Dryers
Need a wiring diagram for emerson k55hweym 3739
green is ground. white is common. blue and orange are hi speed/low speed. brown goes to the capacitor.
Both motors should have the wire diagram on the side of the motor.
Jul 03, 2009 | Emerson Quiet Kool 10MW42K Air Conditioner
95 lumina with cut cables on the tranny plug
I don't have a diagram so am just going to advise you to clean the wires and see if they are color coded, if they are you just have to connect color to color and since it is a car, they probably are. If you end up with a several same color wires and the others are coded, the same color ones probably connect to the same place electrically and can be connected to any the same color.
You can also look very carefully at the ends of the wires and possibly pick out the ones that go together.
Good Luck.
May 08, 2009 | 1995 Chevrolet Lumina
Wiring
The new thermostat (I assume you must be changing one) will have several possible scenarios. If you have two elements and thermostats you look for the diagram that says two elements working NON-SIMULTANEOUSLY. In other words the top element heats until the thermostat is satisfied and then, and only then the power is sent to the bottom thermostat. The wiring diagram will have the numbers and colors of the wires for everything in the heater except your feed wires. Those colors don't really matter much. You will have three conductors--two hot wires and (likely) a bare ground wire.
Hope this helps.
Mike
Apr 05, 2009 | Water Heaters
Kitchen Ranges Logo
188 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
