Didn't work Tried that still nothing... Can't reflash either as the 3.5 floppy won't read. ->R
  • archerr Apr 28, 2008
    Rechecked all ribbon cables - all ok.
    Changed the mobo and powersupply....still no activity on the
    floppy drive when powering up.
    ->R
    Sergeant:
  • 291 Answers
Archerr, what did u try?, I don't know, I can't help u! as per 3.5 floppy, check how u connected the ribbon cable.Pin#1 on mother board to red or colored wire on ribbon(pin#1) the pin#1 [red or colored] that goes to the floppy is usually connected FACING towards the power connector [usually 4 pins in line, almost always on the left side of floppy. the connection to h/d(hard drive)on the board looks the same.Usually h/d#1 & h/d#2 are side by side and the floppy connector usually is a distance away by itself.
Get a bootable 3.5"[with ANY operating system] and boot up with the floppy, you'll will know when it works.Then get back with" Tried that still nothing..."
Posted on Apr 26, 2008
  • Daniel Martinez
    Daniel Martinez Apr 30, 2008
    Did u mess with the mobo BIOS settings, speed it up ?, did u cange any jumpers to speed up the cpu? did u take out or put jumper pins without the mother board[mobo] directions? goto BIOS setup and goto EVERY menu, and submenu and see if there is a "Default" setup, do dar [do that] usually some F-function button. Go to EVERY menu, and submenu...!!
    luck, buddy!!
Can a failed bios update be recovered?
Do you have a floppy drive in this PC? From what I've found you you *may* be able to fix it, but it will more than likely require a floppy drive and a disk. Also, you would need another computer to be able to get the files prepared for the floppy disk, and that computer also would need a floppy drive.
In a nutshell, you would use the 2nd PC to make yourself a boot disk, then put the boot disk in the broke PC and turn it on. In theory, if all goes will, it will read the disk and restore the BIOS.
But you may have to change some files on the disk so it will boot to the BIOS recovery program.
If you do have a floppy drive in the dead PC, turn it on and see if the floppy drive light comes on at all. If it does, then the computer is trying to access the floppy drive, which may allow it to read a disk. You will stand a better chance of getting any recovery to work.
Mar 26, 2014 | Medion Computers & Internet
Won't read the floppy Discs
follow these solutions in the steps I list
1. Reinstall drivers
2. Unplug the floppy drive from the mother board and plug it back in, reboot
3. Try another floppy drive.
4. If all else fails, it may be an issue with the OS.
Sep 20, 2012 | Mitsumi (FA404MBLACK) (fa404m/black)...
Toshiba laptop won't read DVDs.
try to reinstall all videos players and videos plugins like flash and directx or others
May 21, 2017 | Toshiba Satellite L505-S5966 Notebook
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
http://www.bootdisk.com/
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
2001 BMW 330i wont start. Immobolizer?
Sounds like a dead battery or a dead starter. Try using a jump box or jump start first.
Feb 27, 2010 | Anti-theft Alarm System 3 Series E90 E92...
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
Computers & Internet Logo
319 people viewed this question
David Payne
David Payne
