Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
XP 2070 Won't Stop Beeping
When I plug in the machine, no matter what I do, it just keeps beeping. I set the time per the instructions I found, but after that it just beeps. If I hit the Coffee button, it will brew a pot of coffee, but all the time it continues to beep. Any suggestions would be appreciated.
  • 1 more comment
  • Anonymous Dec 05, 2008
    Plug in the machine, set time, push espresso on/off switch until stops blinking, then the machine led starts blinking and beeping. The coffee machine works fine, cannot get it to brew a shot of espresso.
  • tif7402 Dec 05, 2008
    Plug in the machine, set time, turn on/off switch until stops blinking, the pump sounds like it sucks in water. When the light stops blinking and I go to push the 1/2 cup espresso button the LED display and the alarm start blinking and going off. The only way to get it to stop is to unplug the machine. The coffee pot brews coffee fine.
  • Anonymous Jan 20, 2009
    Plug in the machine, set time, turn on/off switch until stops blinking, the pump sounds like it sucks in water. When the light stops blinking and I go to push the 1/2 cup espresso button the LED display and the alarm start blinking and going off. The only way to get it to stop is to unplug the machine. The coffee pot brews coffee fine. Any solution please?!
  • 31 Answers
Okay, I had the same problem, started beeping and lights flashing one day, unplugged it and it was okay for a few days then this started happening more often until the machine just beeped and blinked all the time and would not make espresso. When I called Krups customer service I was told it sound like a circuit board problem and to send it in, yes its under warranty but I have to pay shipping both ways, so I decided to check it out myself. So here is the bottom line and what worked for me, I removed the espresso screen (above coffee grounds holder, 1 phillips screw) and ran 4 tank fulls of descaler thru the machine. the hard part was getting it to pump thru the machine. I found if I ran water thru the hot water/steam nozzle first I could get it to run 1 or 2 cycles, I also found that by removing the water tank and turning the system on for a few seconds and running pump dry (not recommended) I could get it to cycle without blinking for a few turns. Ran the 4 tanks of descaler thru, then ran 4-5 tanks of water thru into a bowl until it ran thru clean. The machine is 4 months old and I was shocked at the amount of crud that came out. It now runs fine and no more blinking, If indeed this is the fix for this you would think someone at Krups would have a clue, but I guess there a useless a the owners manual for the xp2070.
Thanks and I hope this helps.
John
Posted on Jun 08, 2009
  • 56 Answers
Sometimes water spills into the area around the water container which prevents it from firmly sealing into the seat/valve. Another common problem with this unit is that the screws holding this seat/valve in place are lose from the factory which results in water leaking and air infiltration which causes the pump to not work properly. I had to open mine up, take a couple of things apart and tighten the screws. Unit has been working fine ever since and no water leaks.
Posted on Apr 15, 2009
  • Jambam Apr 15, 2009
    Opening the unit is not recommended since it would void your warranty. Personally I love challenges like this and the opportunity to see how things work, diagnos the problem and get the satisfaction of fixing it. If you have the leaking seat/valve problem then it's a manufacturing issue and should be covered under warranty.
Same problem, taking this thing back to lowes.
Posted on Jul 05, 2008
Iturn on my desktop and it just keeps beeping nothing on monitor?
Pull your ram sticks out, leaving only one in place (doesn't matter which spot it's in). If beeping stops and computer boots, you found it. Continue replacing ram sticks until beep returns, and you've found the bad stick.
On the suspect ram stick, try this. Take the eraser side of a pencil, and work the eraser up/down, back/forth on the gold contacts of the ram. What you're trying to do is to clean the contacts with the eraser (stop laughing, it works!).
Try that ram again, if the beeping stops you've saved a ram stick. If not, I'm afraid it's shot.
Best,
Lower
Apr 14, 2016 | HP Computers & Internet
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Won t stop beeping
if it's just continuously beeping, then you may have a shorted control board. This isn't an error code, so if it keeps beeping, you may need to replace the control board itself.
Dec 18, 2013 | GE Dishwashers
My 6.5 wf s6607TC will spin for a few times then would stop and keeps beeping. Ii tired opening and closing the lid but it didnt stop. Then i left it beeping, it would stop on its own but then it wont...
When it spin for a few times then stops the beeping is telling you to redistribute the washing(clothes) in different positions as it is out of balance Opening and closing the lid without doing this is a waste of time as you haven't fixed the problem.
Mar 09, 2013 | Washing Machines
My em 200 cuisinart espresso maker stops brewing and beeps
My em 200 Cuisinart express
maker start and stop and beeps what I do
Jan 14, 2013 | Cuisinart EM-200 Espresso Machine
Slow Cooker Beeps only after a few minutes and won't stop.
4 years later... I'm pretty sure it has to do with liquid in the slow cooker (maybe relating to temperature also so it doesn't overheat/burn your meal?). I just threw in some short ribs and a thick (and somewhat scant for the cooker's capacity) bbq sauce. It started beeping and beeping and beeping at fairly frequent intervals. I added about a cup of hot water and the beeping stopped.
Jun 30, 2012 | Kitchen Appliances - Others
Washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
1,104 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
