Question about Speed Clausing 15" Variable Floor Model Drill Press
Spindle wont go down - Speed Clausing 15" Variable Floor Model Drill Press
  • 3,740 Answers
Open the upper housing and look at the spindle press gearing. If something like a nut or a foreign object has most likely fallen into the gear mesh area. It will move slightly and then LOCK yet return to the up position. If this is not what is causing your issue then please provide an exact make and model number so we can use reference material to resolve it.
Thanks for choosing FixYa.
Kelly
Posted on Jul 30, 2010
Bobbin stuck on bobbin winder spindle
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Nov 29, 2012 | White Sewing 2037 Mechanical Sewing...
Wont spin or play discs
Two possibilities, The Spindle motor need lubrication or the unit is in such condition that the pickup can not focus on the disc. This happen if the spindle platter goes out of specs- they slip down mostly. The CD olayer wants to get a Focus OK signal before the disc is told to spin.
Sep 29, 2012 | Sony Mxd-d5c Cd Changer Rare
Why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
Jul 18, 2012 | Singer 8280 Mechanical Sewing Machine
I cant figure out how to fill the bobbin
it's possible that your thread guide may be off some & needs to be adjusted
or the bobbin isn't being pushed down far enough on the spindle to click into place to hold good
Mar 16, 2012 | Janome 4623 Mechanical Sewing Machine
How do you lift the platter off the turntable of a aiwa pze860 it wont just lift up ?
If the platter doesn't lift straight up, look for a retaining clip (a circlip) on the center spindle holding the platter down. If there is one, use a small screwdriver to pop the clip free, but be careful not to lose it. Once the clip is off, the platter will lift up. If there is no clip, the platter is just seized on the spindle, and a good tug will lift it free.
Oct 26, 2010 | Aiwa PX-E860 Turntable
Bit wont tighten down in collet
Get a new collet and nut the 1/2" collet is crappy, it is too thin and pushes out of the nut easily.
You may also make sure that the collet did not seperate from the nut. remove the nut completely and if the collet is not attached, remove the collet from the spindle, insert inthe nut and then insert the bit through the collet while holding it and then put the hole thing back on the spindle (mtor shaft) and tighten it.
Oct 19, 2010 | Hitachi M12V2 3Router
I've replaced inner and outer bearings,new hub,seal etc.. on my 89 GMC seirra 1500 2wd and the innerbearing wont go up on spindle enough to get the nut on.How do I fix this?
Check to see if the spindle is scared up,or has a bur on it,keeping the hub from going all the way on,if it has,take a flat steel file and file the bur down.Make sure you have the right replacement part,
Jan 02, 2010 | 1989 GMC C1500
The ball joint will not go down in the spindle the bigger of the shaft wont go down
you either have the wrong size joints or you will have to press them in with a press tool that you can borrow from oraily auto parts with a deposit untill you return them. berrydalewolf
Oct 22, 2009 | 1998 Ford Ranger SuperCab
Im having trouble put in a ball joint in my 2000 taurus can anyon
The ball joint has pressure on it from the strut,it may be loose in the spindle,and you dont realise this.It takes a large bar,and two people to push it down far enough to remove it from the spindle.If you are sure it has not turned loose of the spindle,the take a big hammer and hit the spindle real hard multiple times near the ball joint,all around the spindle.Do not hit the ball joint itself.just where the ball joint stud goes threw the spindle,not the ball joint stud(don`t hit the stud)This will jar it free,but you will have to use a large pry bar and push down on the spindle control arm.
Sep 23, 2009 | 2000 Ford Taurus
Remove pulley on mower deck spindle
These are generally held on with just one large nut, I recommend you use a impact wrench otherwise it mau prove difficult ( you wont be able to hold the spindle tight enough) and certainly you will need a impact wrench to reassemble the spindle
Aug 22, 2009 | John Deere Garden
Speed Clausing 15" Variable  Floor Model Drill Press Logo
90 people viewed this question
Top Speed Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Speed Drill Expert? Answer questions, earn points and help others
