Question about Insignia 32" 720p Flat-Panel LCD HDTV
Digital over the air tv signal cuts out, but have concluded it isn't the signal from the antenae. It is like it freezes. Normally gets worse the longer the tv is on. what are the possible problems & solutions?
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Cant get channel 11 when i hook my converter box to this tv is there a way i can i get regular tv without it
No,if this tv is an analog tv mean tv have a big back cover and have a heavy CRT-(tv tube).Must have a good antena like a digital antena or move antena around to left or right to pick up channel 11,might lost some other channels than.This tv now can't pick up digital signal now without the tv converter box if u want to pick up free DTV air broadcasting tv signal,it all broadcasting in DTV free air in all digital now.
Apr 14, 2011 | Apex Digital AT2402 24" TV
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can you get a signal without cable or a converter box
Yes,if ur tv is a LCD or a Plasma tvs.It have the tuner inside already it will recieve the digital tv free air brocast.Must have a good antena though like a roof antena,or a digital inside antena.To get excellent signal.So it would cut in and out the broscast of the free digital signal.
May 25, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Error Code E202, no picture, Sharp Aquos LC-45GD1E
Ur tv is not getting a broadcast signal,or ur tv cable or free air signal not getting from air antena,cables or dishes signals,or strong enough comming through.Get a better antena,like a digital antena,or a roof antena for better free air signal,cables or telicoms signals check ur boxes,push the power button OFF/ON to reboot it,to get signal back.
Apr 05, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
My 32" freezes up on certain channels and the remote doesn't work. We have to unplug the tv? How can we get this fixed
It this a Free over the air Signal?Get a better signal source like a roof antena or digital antena.If it cable or satalite then backlight video board it the problems must change to to fix the problems.
Nov 28, 2009 | Vizio VO47L 47 in. LCD TV
Ch 9 picture froizen.has sound.cannot change
U have cable,some kind of pay tv?Tries unplug the cable box,replug the box for reset or to update new solfware for the box.If u have free air tv,get better antena like out side door antena or a digital antena.Also should change the batteries in ur remote and clean the IR lights both remote and tv make sure no blocking path to signal.
Oct 31, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Digital picture freezes for split second every now and again
U have Cable,Satalite,or Teleticom Siginals ur incoming signals 99.999%.Digital antena about 95%.Roof antena about 90%.Indoor Analog antena about 89%.Yes the signals is varies u will have freezes,not ur tv
Oct 15, 2009 | Televison & Video
TV picture skips/freezes every 3 minutes
U have cable or other?Call the companies.If u have over the air signal.Get a good out side antena or a digial signal antena.
Aug 25, 2009 | Televison & Video
Insignia 32" 720p Flat-Panel LCD HDTV Logo
82 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
