Question about Amana Haier AP125HD Air Conditioner
My air conditioner turns on cool then after 3 min it goes warm
  • Amana Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 30, 2010
My commercial cool air conditioner goes off after 5 min. The stop light is flashing? I can't get it to go on?
It's going thru the defrost cycle. Once that ends, the unit should restart. If it doesn't wait until 3 minutes have elapsed, after the stop light goes out and restart the unit. If that fails, turn the Master ON/OFF Switch to OFF & unplug the unit. Wait 15 minutes, plug the unit back in and turn the Master ON/OFF Switch to ON. The unit should have reverted back to the original factory settings. If so, reset the controls as you like.
I hope this helped you and thanks for choosing FixYa.
Jul 24, 2011 | Haier CPN14XC9 Air Conditioner
Frigidaire FRA256ST2 compressor stays on for about 3 mins then goes off for about 3 minutes, we have the temp set for 76 and it says 80 on the thermostat
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 02, 2011 | Frigidaire FRA256ST2 WallWindow Air...
B 2200 - Fan still working - no cool air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 08, 2011 | Dometic Rooftop RV Air Conditioner
Cool air comes out when the heat turns on. When I switch to Em heat, warm air comes out. Over the summer the air worker great, however when I switched to heat on the thermostat, cool air came out. Why?
Check the following. 1. Your setting temp must be higher +3 than room temp. 2. Check heating sensor.3. And also heater element.(If it's reversal valve, checke RV is working)
Dec 12, 2010 | Weather King 10AJA3601AH Air Conditioner
Chilled air flow is changing to warm air flow periodically, approx. 3-4 min chilled then 3-4 min warm as ambient air temp.
Sounds like a classic floating restriction. An A/C unit with a leak on the low pressure side can **** in moisture which is then pumped through the system, as it goes through the metering device, typically a capillary (very thin) tube, it freezes, creating a blockage. The discharge air warms, the ice melts and circulates again. During the circulation, you get cool air.
The problem could also be electrical. A faulty overload device or the compressor in the process of failure, could give these symptoms. Best thing to do is shut it off and have a pro take a look. If it is a window unit, look for a local refrigeration school to check it out. THey will often do the repair for the cost of the parts.
Jul 19, 2010 | Heating & Cooling
My Air Conditioner does not get cold after I turned it off and turned it back on. I have now turned the themostat off about 20 mins ago
Air conditioners need a few mins to stabilize (the fluid in the lines) after they are shut off in the middle of operation. The comperssor will normally time out for several mins after it shuts off (or you shut it ofF) preventing it from coming back on within that time. So if you turn it off, and then right back on, you can expect warm air for several mins untill it times out.
Jun 17, 2009 | Honeywell Electronic Programmable...
Cant get air compressor to kick on. did turning it off and on withoutn waiting affect it?
I don't think that not waiting the 3 min period would hurt it to the point of not working. my guess is that the thermostat is bad/broken. Another possibility could be the wiring has come loose or been chewed through (depending on where it is stored for the winter) if you are mechanically and technically inclined pop off the cover and have a look always making sure it is unplugged... if you cant resolve the issue and it is under warranty return it to the store if possible or the manufacturer for repair/replacement. also I wouldn't mention not waiting 3 min between power cycles if you send it back as i don't see that being the cause of the problem.
Jun 01, 2009 | Whirlpool ACQ158XP Wall/Window Air...
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
152 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
