Question about Eddie Bauer B00008PC3T Portable DVD Player with Screen
Screen will not tun on
When I plug my DVD player in the power source, the power light turns on and its red. When I push the power button, it just stays red. Is this the way it should be? Anyway, I can put a DVD in, but the screen just stays black even though I can hear the DVD spinning. The screen never turns on and the menu never appears. Not sure what is going on. This is the first time I've used it in 6 months. Leaving on a road trip tomorrow morning. If anyone can answer this tonight--with any helpful suggestions, it would be appreciated. Thanks for the help!
  • Eddie Bauer Master
  • 17,130 Answers
Put the set on for several hours and let the electronics warm up. It is possible that some capacitors have dryed and putting on the set for sometime can build up the charge and help to retain the circuit to perform in order. This is all what could be done and hope you have not started on the trip. It is important that any electronics units must be in action at least some time as some low quality components can malfunction with aging in course of time. If this wont solve then you will need help to open and probe for fault inthe power/ display unit. Good luck Good day
Posted on Jul 30, 2010
TV has static but no picture. When I turn on the TV, I hear 2 clicks and static. Pushing the power button again, static stops and red LED light turns on. After 15 min. TV automatically shuts off.
Check your antenna is plugged in the right place.
Switch TV on then goto it's menu setting, if the menu appears then at least you know the screen works.
As a test, plug in a DVD player to one of the HDMI ports and try to play something. Make sure you select the proper input source from the source menu and see if you get a picture.
If you do then it narrows the problem down.
Next, from the menu, select TV source to see if picture comes.
There are a number of other sequences depending on what decoder or Viewer box you have, if it's just Freeview antenna then you may have a problem with that.
Make sure you've done the auto tune procedures too.....
Oct 11, 2016 | Televison & Video
Audiovox: cd micro system for iPod. model# CD6229i: red standby light is on but blue display screen stays blank and no buttons work.
push the standby button and it should turn on the blue display should light up brighter make sure the speakers are pluged through the back and change the button that says source.. and change it too fm radio you should hear the static. hope this helps
Jan 01, 2010 | Durabrand Televison & Video
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
Lcd won't turn on
The on/off Button is on the leftside of the TV on the bottom underneith.
May 18, 2008 | Konka KDL32AT23U 32 in. LCD Television
Disney Princess dvd player will NOT turn on or eject.
On front of television is the video, left and right audio plug ins. This is where you will plug the adapters from your dvd player. They are color coded for easy installation. Step2Make sure the adapter is also plugged in to back of dvd player. Step3Plug dvd player into power source and turn on. Step4On the front of television there is a tv/av button. Press this button twice or until it says video 2 in upper left hand corner of television. Step5Insert movie into dvd player and enjoy. To get your tv back to cable press tv/av button once.
Apr 20, 2008 | Disney Princess MCP DVD2050P DVD Player
New Portable DVD wont turn on.
Push the ( IN OUT Button) and check the ( Source Button )
Mar 06, 2008 | Polaroid PDM-0082 Portable DVD Player
No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Oct 04, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Eddie Bauer B00008PC3T Portable DVD Player with Screen Logo
44 people viewed this question
Top Eddie Bauer Televison & Video Experts
Marvin
Marvin
Are you an Eddie Bauer Televison and Video Expert? Answer questions, earn points and help others
