Question about Whirlpool Duet GHW9150P Front Load Washer
New-I.m doing a load of towels and on the spin cycle it started jumping real bad. I took some towels out to reduce the load- same thing. This is our first load in a new washer. What.s wrong?
    President:
  • 670 Answers
Did you remove all the shipping material and bolts before running the load?
Posted on Jul 30, 2010
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Anytime this machine goes into a spin cycle it is grossly out of balance. we have tried adjusting the load; reducing the size of the load; we have gone to just one towel in the washer and still out of...
Are the locking nuts tight on all 4 legs? If not, tighten all locking nuts after leveling machine. Also, place a glass of water about 18" in front of machine while spinning and see if water moves. If it does, you may have flooring issues.
Sep 11, 2010 | GE Energy Star WCVH6260F Front Load Washer
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool top load wash machine does not spin
Check your lid switch it may be bad.
Mar 18, 2009 | Washing Machines
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Bumping on Spin Cycle
Front Loaders do n ot do so well on smooth, shiny or soft flooring. they tend to jump all over the place on the spin cycle.
There are some things that you can do to improve the situation.
I learned this AFTER I paid for a service call on mine.
We placed a commercial style rug with a thick rubber backing all the way underneath our machine. You can buy the smaller ones usually at hardware stores.
Also, be very selective about loading. Wash towels with towels, and shirts and undies together, and jeans all together. In other words, no mixed weight loads.
I know this is a frustrating problem, but this hints will help. Good luck to you and thank you for using Fixya. Your rating is always appreciated.
Aug 25, 2008 | GE WSXH208A Front Load Washer
MAYTAG WASHER - TOP LOAD MODEL #HAV2360AWW
You need to replace the wax ring. Mine did the same thing. My washer was new and still on warranty. I had them replace the ring and it was good for awhile and then it started again. So I called Maytag again and they got me a new washer. I don't have that problem anymore unless I do a lot of towels and it gets of balance. Hope this helps.
Aug 13, 2008 | Washing Machines
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
77 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
