Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Lightening "hit" our TV. The lightening didi not harm the cable box or the plug but the TV now will cut on - the green light comes on - and this it immediately clicks off, I am hoping that since the cable box was also plugged into the same wall socket and the cable of course was hooked to the TV that possible some kind of trip switch or breaker within the Tv has been tripped. What do you think?????
  • 10,594 Answers
Let me know is it Sony KDL-40V2500 or any other model, please check at ear of tv for model number info.
Does standby/power light blinks after tv clicks off, if yes, how many times it blinks after long 3 seconds pause?
Above info will help me to diagnose problem of tv.
Thanks.
Posted on Jul 30, 2010
Recently my house got struck by lightening. It blew a few things out, one being the tv. It's a Sanyo Dp39842 42", green light comes on showing that its turned on and sound comes out but no picture.
You need to report to your homeowners insurance. It is normally about as cheap to buy TV nowadays as to repair. Especially one hit by lightning.
Jul 24, 2017 | Sanyo Televison & Video
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
Why won't my TV turn on after a storm?
Your TV might very easily be destroyed now, from lightening damage. Lightening can come in on the cable, on the power line, all sorts of unexpected ways. I've personally been struck by lightening, plenty hard enough to destroy almost any electronic device... and I was working in a basement at the time.
Jul 30, 2014 | Samsung Televison & Video
Hello,my Sony Bravia HD TV (LED & LCD) we suspect that it was struck by lightning,but my other appliances connected on the same power cord as my tv are working fine,so i'm confused..
The power surge from lightening can come in thru the antenna or cable box. Also just the proximity of lightening can damage one item and not another. An ic chip can be destroyed from the charge in the air.Likely took out power and main brd both.
Mar 19, 2014 | Sony "KLV-40BX400 40"" 1080p Multi-System...
I have a panosonic plasma 42 inch tv. After a storm all I get when I turn it on is black and white static but all the menus display fine
Look to see if the rear video/audio inputs work (DVD etc) and if they do the damage is at the tuner in the set (nearby lightening can discharge into the cable or wires for signal.)
If using a box (cable or satellite) it may have took the hit.
A good idea if lightening storm is to not only unplug set (static discharge can come in via the power cord also) but disconnect signal source from set.
I have in extreme cases seen a nearby strike get in via the power lines and destroy almost every appliance plugged in even if not on.
Dec 14, 2012 | Televison & Video
My sound is done on the TV- it was working fine last evening and today the sound has disappeared - i may have hit a wrong button- but not the mute one- i checked that alread
Did you unplug for any reason? I unplugged cable box and tv due to lightening and lost my sound when I plugged back in...had to go into the cable box menu under audio and set my output to "Stereo" instead of "TV Speakers"...frustrating, I know!
Aug 18, 2011 | Insignia IS-LCDTV32 32 in. Television
My Hitachi comes on but no cable picture unless I
now do you have a cable box if you do disgard
if not tray to rescan for chanels and after the tvv is done scaning
hit menu
then
setup
then
rest software
then
no for resting the tv to the manufacter setting after going off
and that would take care of the problem
Jul 30, 2009 | Hitachi 42HDS69 42 in. Plasma Television
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
