Question about Epson Stylus Photo 1280 InkJet Printer
Printer error epson stylus photo 1280
Printer error and ink cartridge would not come out
  • 1,218 Answers
Check the following information if your printer not printing ink
http://www.fixyourownprinter.com/forums/printer/68130#2
Posted on Aug 25, 2010
  • 532 Answers
Press down the printer error epson stylus photo 1280 - fonte1.gif ink cartridge replacement button. The print head moves left to the Ink cartridge replacement position. The fontp.gif power light beginsprinter error epson stylus photo 1280 - fontb1.gif and the fontb1.gif error light begins to flash or remains on.
Lift up the ink cartridge clamp as far as it will go. Take the cartridge out of the printer.
The cartridge will not come out unless you lift the clamp.
Posted on Jul 30, 2010
4 Suggested Answers
sherlyn c
  • 134 Answers
SOURCE: I need a repair service for EPSON stylus photo
Please log on to epson.com. Click on north america, then usa. Go to the drivers and support page. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
Posted on May 04, 2009
57 varieties
  • 1653 Answers
SOURCE: is there a windows 7 driver for the Epson 1280???
There is no specific Windows 7 driver but you can download the latest version of Epson EasyPrint for Win 7 at the following Epson support link
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14387&prodoid=28907797&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=26&y=10
The current official word on drivers is to continue to use the Vista 32bit driver until one is released for Win7.
Posted on Nov 12, 2009
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
Epson Photo Stylus 1280 print heads do not work
The problem is the print head, The ink cartrige for this printer is just a little bottle of ink. What really causes problem in it IS THE CLOGGED HEAD. If you have skill to reach thepen of the head (part that touchs the paper) use a quill tip or rag soak on water and clean it. Or go to EPSON SITE AND ORDER A HEAD CLEANNER FLUID TO POUR INSIDE THE HEAD AND CLEAN IT.
Oct 23, 2012 | Epson Stylus Photo 1280 InkJet Printer
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
I'm trying to resurrect an old Epson 1280 Photo Stylus. I've changed ink cartridges, and run the head cleaning/nozzle check utility numerous times, but nothing prints out on any test pages, nor on any...
It's time to "cut your losses"; either the electronics that tells the inkjets when to shoot ink is screwy, or the inkjets are totally plugged, despite the "cleaning" cycles.
Responsibly recycle the printer, and buy a new printer.
Maybe, try to find another Epson that accepts the same ink-cartridges that you recently inserted into the old printer.
Nov 19, 2009 | Epson Stylus Photo 1280 InkJet Printer
I need a repair service for EPSON stylus photo 1280 The paper intake it broken. Prints feed through crooked. Also, new ink cartridges print extremely off colors.
Apr 30, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson stylus photo 1280 Isn't the printer working if I only have a black ink full?
It doesn't matter whether the cartridges are full, but both cartridges need to have ink in order for the 1280 to work.
Jan 17, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
Black lines on prints
Remove the cartridge.....
using a cotton bud clean the ink nozzle area on the cartridge for excess ink..take extra care not to damage the nozzles
... while at it take a piece of rag and try to clean the..service station area(this is where the cartridge goes to the side of the printer)for ink build ups....try to clean the rubbers that wipe the ink off the head as it runs across ..this is near the service station area clean well
it just requires cleaning..try to use little bit of cleaning solution that is available for that particular model..if not use bit of alcohol but do not use it on the cartridge itself ..make sure the alcohol is properly dried as not to damage the head
do reply if this helped
Nov 11, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo 1280 dead
that's most likely a system board failure...that's what controls the function of startup positioning
Jun 16, 2008 | Epson Stylus Photo 1280 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo 1280 InkJet Printer Logo
392 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
