Question about Acer AL2016W 20" LCD Monitor
New 20 inch acer h203 will not let me display full resolution on e machine running xp. help!
3 Suggested Answers
SOURCE: 20" acer monitor not able to display properly on my computer is Xp based
RIght-Click on the desktop and Click properties, then go to the advanced tab and increase the resolution using the slider, until the image of your screen (the rectangle with the 1 inside it), is also widescreen.
If possible, find your manual or box from the monitor, and look for its resolution, and then change it to match that.
Posted on Feb 12, 2008
  • 121 Answers
SOURCE: display does not fill screen completely
ok right click anywhere on the screen go to the bottom and click properties now there will be a couple of tabs at the tom desktop screen saver you want settings raise your resolution to about 1200 x800 or higher i think native for that is the 1680x1240 this should fix your problem
Posted on Nov 25, 2009
Acer V223W off center
it happened to me. I changed computers but that did not solve the problem so it's not the video card. what did help was I turned off the monitor to reboot it then, using a different computer I reset the resolution to the lowest possible setting. when the monitor adjusted to the new resolution it reset itself. I then set it back to the higher resolution and everything was centered again.
Mar 12, 2013 | Acer V223W 22 inch Monitor
Installed new Acer P236H to a few years old Windows XP system. Graphics, pictures are squished and skewed, text appears fine. Have played with settings, OSD and Win Display. Never resolved problem, but...
What device-resolution combinations is your computer's video-card capable of? 1024 by 768 by 60 Hz? 1024 by 1024? Anything that matches that "native" resolution of the ACER?
You may need to upgrade your video-card, to support the "native" resolution of the ACER.
Jan 15, 2011 | Acer P235H LCD Monitor
Display does not fill screen completely
Nov 25, 2009 | Acer X203H bd Monitor
Monitor will not display full screen.
Usually there is a adjustment tool built in with your monitor who let you adjust this. You will be able to move it up-right-left-right along with a few other options about brightness/contrast, gamut and so on. Let me know if you still need help with this
Jun 08, 2009 | Acer X203W 20" LCD Monitor
2 problems: 1. Is there a way to make the images on my 19 inch acer lcd monitor not appear stretched? 2. How do I get a screen resolution of 1440 x 900 (It's not one of the options in my display...
1. The only way to avoid stretching of images is by increasing the resolution. Many 19-inch monitors with conventional (4:3) aspect ratios have 1600 x 1200 pixel resolution. The 1600 x 1200 resolution is ideal for graphic artists and those who work with photos, since it's close to the resolution of a 2-megapixel digital photo.
2. You can double check by going to the display properties - Settings- Advanced tab below the screen resolution slider, choosing the Adapter tab, click List all modes and that will settle it once and for all. If 1440 x 990 isn't listed you're likely going to have to buy a graphics card that can reproduce that resolution.
Also try and update the driver for your graphics card.
Jul 06, 2008 | Acer Computers & Internet
Driver
If you mean that you can't get the full color response and can not change the screen resolution beyond 640 X 480 and only 256 colors.
Sounds like you need to load the "Mother Board" driver for the VGA port. If you have a PCI video card, make sure your onboard video is turned off or disabled in the CMOS setup.
KDonald
Jun 02, 2008 | Acer AL1916Ws (Silver, Black) 19 inch...
Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Al1917w lcd monitor resolution problem
I have the same problem! Here's what I did: Go into the Display control panel, go to SETTINGS, click on ADVANCED, and then on the ADAPTER tab, then on LIST ALL MODES. There are several 1400 settings. Try them out and see which one is best for you.
Jul 30, 2007 | Acer AL1917W LCD Monitor
Acer AL2016W 20" LCD Monitor Logo
177 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
