Question about Husqvarna 60'' Zero Turn Lawn Mower 34hp Kawasaki
It shouts off after it get's hot. 1 to 3 hrs of running time. I think it maybe the coil packs. It will restart but has a miss.
  • 755 Answers
That is a good call! You can test for spark the next time the mower wont start and confirm it.
You should remove the engine cover and see if the airpath is blocked with dirt, debris or even animal nests. When you are there you can swap the coil(s) out. You should find out about proper gap specs for the style coil you are replacing by looking it up either on the Husq or Kawi website. Whichever is more specific.
Good luck and be carefull.
Posted on Jul 30, 2010
CAR STILL HAS ROUGH ILDE OR MISS FIRE. AFTER..1.CHANGED ALL SPARG PLUGS AND ALL COIL PACKS.2. CLEANED MASS AIR FLOW SENSOR,AIR FILTER 3. TIGHTEND UP A FEW AIR LINES TO INTAKE TO MAKE SURE NO LEAKS
you started to waste money the minute you neglected to have the fault codes read first
besides all the things you have done , misfires are predominantly from injector faults ( dirty tips and wiring) and low fuel pressure
At 151.000 miles I would have read the fault codes then shouted it a new set of injectors before plugs and coils and had the fuel pressure tested to see if the pressure regulator was operational
Dec 25, 2015 | Lincoln Cars & Trucks
I had a missfire code saying cylinder 2 n it was missing but drivable.. Now its not its shaking horribly n i put a new new coil pack on n plug n wires n still rough low idle n coil pack is super hot to...
Try switching the new coil pack to a different cylinder and check if the miss follows the new coil pack or stays at #2. Just because the coil pack is new don't mean it cant be bad also. You did say it was getting real hot.
Mar 10, 2015 | Cars & Trucks
Chrysler neon not fireing on 1 and 4 cyl
I would be more inclined to think the wiring in the coil pack for that coil may have a problem. Have a shop check your ignition system, before springing for a new pcm. There should be a hot wire to the coil primary wire going to that coil. May have to run continuity tests on the wiring for the coil pack. Or if you could find a used coil pack, and use your good coils on it to try it.
Dec 01, 2013 | Cars & Trucks
1998 ford escort zx2 car runs great till it reachs normal operating temp range then it misses like crazy. put in a new fuel pump that didnt help tried new coil pack that didnt help either its not over...
ignition module , that the coil packs sit on ,was the problem on my car. had the same symptoms .ran fine till it warmed up then it started missing like crazy
Nov 03, 2013 | 1998 Ford Escort
Why does my 93 Caravan Start fine and run great till it warms up then dies and wont start untill it cools back down.
I had the same problem a few years ago and it was the coil pack breaking down. If it starts missing before it dies id get a new coil pack. Before u buy a coil pack you need to get it warm again and just before it dies look underneath the vehicle to see if the catalytic converter is starting to get hot, if it is hot and usually getting red hot, its stopped up.It will fool you in to thinking that the coil is bad.
Nov 05, 2012 | 1993 Dodge Caravan
1994 Mitsubishi Diamante. I had this problem for a while now. When the engine is hot it gets worth. The engine is miss firing, I replaced spark plugs and wires a year ago. i also replaced Air miter. The...
check or relace your coil pack due to the fact that when a coil pack is going bad it usually looses its umph. when it get hot and that would explain random miss fires
Jun 23, 2010 | 1994 Mitsubishi Diamante
Missing in the rain
o2 sensor mixes the difference of fuel and air. i would think u probably need a new coil pack or distributor cap.
May 27, 2009 | 1995 Ford Thunderbird
1995 buick... steadily misses..
Just went through the same thing - change out the coil packs, one at a time. Coil packs run $30 - 50.
Nov 15, 2008 | 1995 Buick Riviera
Husqvarna 60'' Zero Turn Lawn Mower 34hp Kawasaki Logo
209 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Mike Squire
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
