Question about Samsung SBH500 BT Stereo Headphones Bluetooth Headset
I can not connect it to the PC.....i don`t have any built in blue tooth so using the blue tooth radio......it connects to all kind of cell phone blue tooth devices but can not connect to the SBH500.......any solution ??
4 Suggested Answers
SOURCE: Hi. Can my SBH500 BT Headset pair/connect to a PC?
Make sure the headset is put in pairing mode, to do this, turn the headset off, hold the phone button(big silver round one on the right speaker), then turn the headset on. Hold the button until the blue light goes solid. At this point, your computer should be able to detect it. Be aware, though, that support for bluetooth audio on computers is weak at best.
Posted on Aug 04, 2009
SOURCE: i cant connect my em227 to my nokia cell phone.
i need passcode for em227 so it pairs with black berr
Posted on Jan 02, 2010
kozachek
  • 122 Answers
SOURCE: I want to connect my Blue tooth device to my
In order to pair this headset with your BlackBerry, you need to place the headset in to pairing mode. To do this, press and hold the talk button until the indicator light turns blue and stays lit after blinking.
After you do this, go to the bluetooth setup area and search for a device. Once it locates your headset, it will prompt you for a PIN. This PIN should be the factory default, 0000. I hope this helps!
Posted on Mar 21, 2010
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
After i paired a bluetooth headset with my Nokia E5, it disconnects / connects every 30 - 45 secs. When I make a call or listen to music when bluetooth is connected the line crackles so much that you...
some units cannot handle blue tooth. Check to make sure yours is blue tooth capable. If it is, check your settings both security and blue tooth to ensure there is no conflict. Also check the headset for compatability ratings. Sometimes that is why there is interference.
Jul 04, 2011 | Nokia E5 Cell Phone
How to connect samsung gt c3200 to pc through bluetooth
yu need to install samsung pc suite on yo pc , when yu open the pc suite it will ask you the method yu want to use to connet yo 4ne ,cable or bluetooth.if yo pc don"t have blue tooth yu can buy a blue tooth dongle
Mar 20, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How can my samsung gt-15503 connect to internet through my pc which is connected to an internet.?
You can either use blue tooth which is very slow or you you can install a wireless card in your pc and use your phones wifi system to go on internet. if you have an ADSL land line modem connected to your pc then you also use your phones wifi facility if the modem has a radio antenna connected to it which indicates that it has a wifi connection... Follow the ADSL booklet instructions to address your phone correctly for the connection.
Mar 18, 2011 | Cell Phones
R/sir i could not connect my cellphone to PC how to connect this please help me
For your Cell phone to able to connect to your PC, you must have a cable that can connect your phone to a PC via a USB Cable or your phone must have a Blue tooth wireless adapter on your PC and your Phone.
Install the USB cable driver or the Blue tooth software on your PC.
Connect your phone via the USB cable to your PC, or from your phone search for the blue tooth device of your PC.
Oct 21, 2010 | Computers & Internet
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
How to connect a blue tooth with cell phone
HOW TOCONNECT BLUETOOTH
Take care.
Aug 08, 2010 | Cell Phones
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
How to connect samsung mobile internet without pc suite?
I found A PC blue tooth at wallmart for less that 20 bucks, transfers pics audio everything on all my cells. plugs into usb port all you have to do is install disc from blue tooth, make blue tooth on and visible on cell phone then pair them code 0000
Jun 02, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I do not have data cable I want to connect to PC via blue tooth
GAME DIDNT TRANSFER. PLEASE CHECK BLUETOOTH CONNECTION
Nov 12, 2008 | Nokia 6233 Cellular Phone
Samsung SBH500 BT Stereo Headphones Bluetooth Headset Logo
200 people viewed this question
Top Samsung Radio Communications Experts
ivan georgiev
ivan georgiev
JP Services
JP Services
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
