Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Water Heater pilot will not turn on
I have two heaters one manual and one electric both pilots will not turn on. Both tanks where submerged in water (3-4 ft deep). Any help would be greatly appreciated.
    Scholar:
  • 122 Answers
Replace them both!!
no warrantee is provided on anything that has been submerged in water.
too many things can go wrong once they go under water
Posted on Aug 10, 2010
I have a Rheemglas Fury model # 81VP207, no hot water it is in a trailer home. HELP
I don't recognize the models number, if your water heater is an electric, check the two-pole circuit breaker in the distribution panel to make certain it has not tripped. If it has, try resetting it. If it will not reset, the heater element is probably bad. If the breaker has not tripped, either the thermostat(s) or heating element(s) are bad.
If it's gas, there are several problems that can cause a heater to not start. First is the pilot lit? If not, try holding the gas control down in the pilot position and light it using a match. (The instructions are on a label on the side of the heater). After the pilot lights, turn to "on" position and it will start to reheat the tank. If the pilot will not relight, either the gas control is failed, or (more likely) the thermocouple has failed. (The thermocouple is a very small copper tube that screws into the gas control and the other end is positioned in the flame of the pilot (it monitors the pilot flame to make certain the pilot is burning and only if satisfied, will allow the gas control to turn on and heat the water in the tank).
Hope this helps.
Dec 14, 2014 | Water Water Heaters
I have smoth's hot water tank. problem is pilot lite is off. how do u turn it on?
You have tank-type gas water heater with standing pilot light.
Instructions for lighting pilot light are usually on front of water heater.
Since water heaters vary widely, if you want specific information without guessing, then add a comment with model number that appears on label on side of tank, and also describe the gas control valve on front of unit.
This information will let expert located manual and look up specific information plus troubleshoot steps for that model.
Aug 24, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Best place to start is your manual.
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
Believe I need to buy a Rheem Water Heater Thermocouple. Where do I find them?
If thermocouple is from ordinary tank-type water heater, then it is a generic part with different lengths 15" 17" 21" 24" 30" available at hardware of home center.
I suggest reading manual for installation information, advisories, and required maintenance.
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
There are good utube videos on replacing thermocouple.
Tip of thermocouple has to be positioned in the pilot flame.
The heat on tip of thermocouple causes millivolts of electric current that travel back to the gas control valve and the electrical signal causes gas control valve to keep gas flowing down the pilot tube to the pilot light.
If pilot light blows out or if pilot tube is clogged and needs to be cleaned, or if gas valve has gone bad, then tip of thermocouple cools down and electric signal back to gas control valve causes gas control valve to shut off gas going to pilot.
When attaching thermocouple to gas control valve, it is finger tightened.
Be careful and do not cross-thread thermocouple. Just use your fingers to start the nut.
Finger-tighten thermocouple and then add 1/4 turn using small wrench.
The end of thermocouple has a small piece of insulation that isolates the electric current from body of gas control valve. If thermocouple is overtightened, the insulation is crushed, and electrical current millivolts short out and no signal reaches gas control valve, so gas control valve keeps gas turned off to pilot tube.
If this is a tankless water heater, then open following link with troubleshooting resources and contact information for Rheem.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Upvote the help.
May 20, 2011 | Rheem 36" Water Heater Thermocouple Kit
Water is leaking from a whole in the top of the water heater what is the cause
If water heater is leaking out of a hole, then tank is rusted out and needs to be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
First thing is protect yourself.
Tank could rupture.
Turn off power
-Electric heater: turn off circuit breaker
-Gas heater: turn knob from ON to pilot, so pilot light stays lit.
Open bathtub spout on hot side and release pressure.
Now you're save.
When you need hot water, turn heater on for 1 hour, use hot water, then turn heater off again.
You can limp along like this for a while until heater is replaced.
I buy water heaters at Lowes, Ace, Home Depot, Sears.
Look for scratch and dent.
Look for same size that you have now.
manufactured homes require heater that is made for that application.
Propane and natural gas heaters have different burner.
Always offer 10% less than asking price on any water heater.
You need teflon tape, 10" pipe wrench, new flexible water connectors, and a drip pan, and maybe insulation blanket.
Read how to install gas water heater.
To install electric water heater, open link above because some things are same for both gas and electric.
Difference with electric is there is no gas line, and you connect wires same way that they came off.
Feb 04, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Do we need to shut off the gas or pilot light when draining out sediment on our gas water heater?
Yes you should shut off gas valve & water in to tank. Drain tank fully then turn on water & relight pilot.
Jan 24, 2011 | RELIANCE ELECTRIC WATER HEATER
My heater is not getting hot i can not tell if their is a pilot light or a reset button i don know what to do with the heater it is very different how can i heat my water heater
Reliance makes gas and electric water heaters.
http://www.reliancewaterheaters.com/
Best way to start is to look at label on side of tank.
Label has serial number, model number, plus it will say if heater is gas or electric.
Reliance water heater age is shown in serial number: first digit is letter, second two digits are numbers: for example numbers 02 would be the year 2002.
If water heater is 8-12 years old, it might be time to consider new tank.
Gas water heater has 3 inch metal flue pipe coming out of top of tank.
Gas pilot is probably off.
Relight pilot light: Most gas water heaters today have instructions on side of tank just above gas valve that say how to relight pilot light. Instructions vary by model.
If you have gas water heater that is older, it might be easier to call a plumber.
Electric water heater has panels on front.
Open top panel and push in red reset button.
If you have electric water heater of any age, you can usually fix it yourself same day:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 03, 2010 | RELIANCE ELECTRIC WATER HEATER
This is a new whirlpool hot water heater.Pilot lights, burner fires, water heats up to temp. burner and pilot both shut down. Unit has to be started manually each time
LP OR NAT GAS , IF IT IS LP CHECK GAS PRESSURE @ TANK AND MAKE SURE NOT TO HIGH , IF NAT STILL COULD BE THE PROBLEM HAVE THE GAS COMPANY CK PRESSURE
Feb 22, 2009 | General Electric GE SmartWater Household...
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
54 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
