Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet model lt1045 pto will not engage.3.3 ohm reading on the clutch with the plug disc onned.key switch on but tractor not running get 13 volts on blue wire to tractor ground.
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: A short in the pto wiring perhaps?
Form what you are desribing you have a direct short, probaly in the wiring going to pto. I t has rubbed somewhere and is causing your short. Unplug the wires at connector close to your pto clutch and try it again and see if fuse stuill blows after you unhook it.
If the fuse still blows it is in the wiring going back up to thje switch. If the fuse does not blow after unhooking wiring connector the problem is in the clutch.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
mowerman1857
  • 389 Answers
SOURCE: Cub Cadet LT1045, suddenly stopped, (driving
Locate and check the fuse, replace if necessary. Check battery terminals especially the ground, clean and tighten as needed
Posted on Oct 30, 2009
Testimonial: "you are correct sir,,, finaly saw in the parts list that there was a fuse, ,,,, after a bit of searching I found the fuse and it was blown"
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
Fuse keeps on blowing when I engage the cutter deck
Check that a wire has not been cut. Check the PTO clutch wires as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Sep 28, 2015 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
PTO engages, but, keeps becoming disengaged on LT1042.
Cub Cadets have one of two types of PTOs. The most common is gear driven. The gear teeth of the PTO shaft are very small and thin. If the PTO is engaged without proper clutch action, the gear teeth grind together, trying to engage. A little wear on these gears will cause the surface of the gears to become beveled, and when the PTO comes under load, the beveled surfaces of the gear teeth force the gear lock to disengage. The only option is to replace the worn gears...
The second type of PTO drive is electric clutch. This is a disc type clutch that is engaged by energizing an electromagnet built into the clutch pack... any disruption of electrical power to the clutch pack while under load will cause the clutch to disengage and then possibly try to engage while under load and casues the clutch pack to slip and will overheat almost instantly...
Sep 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Pto will not engage on lt1042
check for power and ground going to the clutch if so look under the machine i have seen a few break the wires near the clutch
Jul 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
PTO will not engage onLt 1046
check the safety switches start with the one on the seat
Jun 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
My lt 1050 will not start without a charger attached. Once its running, the pto will not engage. Thought the battery was dead but battery has 13 v. Starter makes no sound when trying to start. No problems...
Does the battery have good voltage even with the key on? A battery can have 12.6-13 volts with the key off but once it is turned to "ON" it can drop considerably. Lights, solenoids, safety switches, and relays all take voltage from battery. Also check to make sure the battery connections are free of corrosion and tight.
Aug 04, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Engine runs-- PTO will not engage after control switch is pulled
first check the connection at the clutch cub are know for this. also check the fuse block for a blown fuse. then still if nothing check to see if your getting voltage at the clutch. to do this unplug clutch and with a volt meter test for dc voltage. it should read 12-14 volts. if not try changeing the pto switch.
Mar 03, 2010 | Garden
Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Aug 06, 2009 | Oregon Scientific Electric PTO Clutch for...
The electric clutch on my cub cadet lt1045 does not stay running
I had the exact same issue early this mowing season on a LT1045 with 184 hours on it. On a wild hunch I lifted the seat and simply sprayed the PTO shut-off safety switch with electronic contact cleaner/enhancer and have had to problems since.
Jun 29, 2009 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
158 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
