Question about GE Spacemaker JVM1640SJ Microwave Oven
This is the 3rd time part number WB27X10388 needs to be replaced in our microwave. Where is it located and can I do it.
  • 736 Answers
That is a fuse .. look for part number 101 in the following diagram
http://www.partselect.com/PartDetail.aspx?inventory=239525&SourceCode=3
click on the diagram to increase its size ..
you can do the work but make sure its unplugged while the case is apart .. there are potentially fatal voltage and current inside while plugged in .. look for swollen capacitors on the logic board .. (tops bulged up ) thay are normally round with flat tops .. china turned out about a billion of them that are defective.. they typically last a couple of years ..
Posted on Jul 30, 2010
I have a microwave JVM3670SK06  ge what amp fuse does it use
I found a good site to find parts for the microwave. It has the fuse for $7. GE WB27X10388 Line Fuse PartSelect
Here is another search form different sellers.
WB27X0007 GE Microwave Ceramic Fuse Replacement
The fuse info
Specifications:
  • 250 Volt.
  • 15 Amp.
  • Type: Fast Blow.
  • Approx. 1.25"L.
Oct 18, 2015 | GE Microwave Ovens
Defective Magnatron
This is probably because there are some defective capactors in the oven. If you replace the magnatron without replacing the caps your going to be blowing it again. Be vert careful those caps store high voltages and must be discharged before you do anything. It could also be a defective rectifier bridge even if only one diode is bad
Good luck
Mar 10, 2014 | GE JEB1095 Convection/Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
FUSE BLOWN PART WB27X10388
http://www.appliancedepot.com/parts/parts-used/fuse-microwave-ge-wb27x10388-jvm2070sk02-jvm1871sh02.html
That is a supplier for you.
It is a semi surge sand filled ceramic fuse and the rating will be stamped on the end cap.
Hope that helps.
Jan 03, 2011 | GE Advantium SCA2001BSS Microwave Oven
I have a JVM1850 1100 watts. It's not heating. Shortly after we got it I think a fuse blew because we always had to turn the vent on and then the cooking time which worked. Now, it stopped heating all...
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacturer and model. Parts are available at any of the following webistes: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites include illustrated parts listings that can help you locate and properly identify any parts you may need. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 47 in the parts listing (part number WB27X10388). This microwave oven is also equipped with various thermostats that (if blown) can cause similar symptoms to that of a blown line fuse. So, if the line fuse is NOT blown, you may want to check all the thermostats to see if they are still good. You will need to remove each one and measure across the terminals with a multimeter. A good reading is 0 ohms. NOTE: The various thermostats are listed as items 27, 61, 74, and 77 in the parts illustration. The thermostats typically will trip if the oven cavity has been overheated. Cooking items that are high heat producers such as popcorn or baked potatoes in rapid succession can often cause this problem. Allowing the oven cavity to cool a few minutes with the door open between cooking can prevent this from occurring.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Sep 08, 2010 | GE JVM1850 1000 Watts Microwave Oven
Where can I get a 20A 125v fuse for my emerson microwave from?
Most appliance parts places carry the fuse, and it's also available at Home Depot stores if you live near one. If you can't find the ceramic-body type MWO fuse, you can also use a glass type 3AG fuse of the same rating. They are the same size.
Mar 06, 2010 | Microwave Ovens
Microwave has no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytewyteyu
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace Thermostat or Thermal fuse
GE calls them TCOs or thermal cutouts.
There are three in this model and they can all be ordered here.
The reference numbers relate to the drawing here.
REF# PART# DESC
111 WB27X1127 TCO -BOTTOM
59 WB27X10195 TCO -CAVITY
104 WB27X10194 TCO - HOOD
101 WB27X10388 FUSE
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing. It usually shows relative component layout.
Aug 19, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
443 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
