Question about Princeton Digital VL1918 Monitor
Color flashes magenta
Every once in a while, the color on my screen goes from regular white to magenta. While it's kind of pretty, it's harder to read. Any hints? I've already had to replace some of the capacitors that went bad (instructions also on this website). Was hoping this would have been fixed at the same time, but it wasn't.
  • 11,361 Answers
You have check all the pin on the video cable? Try it on another PC? Did you change all the CAPS as a set on the DC side for the 5 and 12vdc section, bad cap can look OK but will have high ESR.
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Posted on Aug 01, 2010
When I turn on the TV it goes to white fuzz then the regular picture flashes periodically. What's wrong?
sounds like bad ariel connection check that first, sometime water get in cable if its fine on dry days that's it.
Apr 04, 2015 | Televison & Video
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
Screen goes white on power on and then shuts down power
This is basically due to a faulty screen. Depending on which screen flashes white when you first turn the DS on, this tells you which screen is faulty. If the bottom screen flashes then it is the top screen that is faulty. If the top screen flashes then it is the bottom screen that is faulty. Screens are fairly easy to fit although the top screen is the harder out of the two, you can buy them off of ebay for around £10 and if you google DS screen replacement there are some good guides out there showing you how to do it.
Hope this helps
Jan 29, 2011 | Nintendo DS Lite Console
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Magenta not printing for color copies or printed photo. After regular cleaning and deep cleaning "M" rows (3) are blank (white).
Check for thin film at bottom side of cartridge, it might be broke. You have to replace color cartidge.
Jun 30, 2010 | Canon MP610 Photo All-In-One Printer
Viewsonice VX2835wm strongly magenta
check u'r degusing section u'r degusing is not working if it works then change CRT
Jul 20, 2009 | Philips 170B4MG 17" LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Magenta TV color goes magenta
CALL HIM BACK . sometimes when we troubleshoot a problem another one pops up ,when troubleshooting we move boards and unplug connectors . there can be dirty connections that pop up when where done and even a broken solder joint as well . he should fix it for free . i know we do and it does happen to us once in a while . good luck
Mar 09, 2009 | Zenith B27A11Z 27" TV
DVD PLAYER PLAYS BLACK AND WHITE
sir/maam it is possible that the DVD player is not compatible with colored tv,s or one more thing is kindly first adjust the screen focus of your tv,,,,thnksss and hope to help you!!!more power
Nov 25, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Magenta cast
I guess it could be several things; perhaps the color temperature of your lights is the culprit. At any rate, it shouldn't be too difficult to correct - here are two suggestions: 1) Shoot in RAW mode so that you can fine-tune color balance after the fact and don't have to get it right in-camera. 2) Shoot a black/white/grey card in the same lighting as your subject. (all three "colors" on the same card) You can then use the eyedropper tool in either curves or levels to set the black and white points, and the grey eyedropper tool (when clicked on the grey in your shot) should get rid of any color cast, magenta or otherwise. Good luck!
Sep 14, 2005 | Canon EOS-10D Digital Camera
Princeton Digital VL1918 Monitor Logo
55 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
