Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
My Whirlpool Duet dryer is making a loud squeeling noise when drying.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Hello, the squelling noise from your dryer may be coming from the drum rollers. May need to be opened up and lubed. It can also be the idler pulley, also can be lubed. Disconnect power, remove lower panel, and see if you can isolate the noise. Oil where necessary. If you can't get to it, the drum wil need to be removed. If something is locked up or damaged, it will need to be replaced. Caution: Don't stick fingers near moving parts when running :-> Hope this helps, Rich
Posted on Jul 31, 2010
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Everything works fine, starts fine etc..however after running for just a few minutes it starts making a very load grinding noise and continues until the machine is finished drying...just can't take it...
Hi bpur04...
You have either a bad drum felt seal and or noisy or faulty drum rollers.
You will need to disassemble the drum assembly to replace your felt seal and your drum rollers.
I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
I am also going to include a link for you to download a user manual for FREE.
Please take time to rate me thumbs up
http://www.whirlpoolappliances.ca/assets/svXmW8P-TLAIvzVs3DbbPjHfLrBQ74kI.pdf
Sep 17, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool Duet dryer WED9200SQ0 that has been
Sounds like it. Or your seal around the door is about to give you a headache.
Nov 06, 2009 | Dryers
Squeeling while drying
worn belt, needs replacing
Oct 07, 2009 | Dryers
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yriur
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
643 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
