Question about Avaya Lands Phones
Ipo 500 system-customer using so8 module cant get incoming ddi number to ring isdn terminal adapter. when i connect my trend into it there is no problem
What is your system config? Is there a Professional upgrade license?
Posted on Jun 03, 2008
WILL NOT CALL OUT SAYS TO CHECK ISDN LINE WE ARE NOT USING ISDN LINES WE USE THE INTERNETWhat's your problem?
When you use the internet you are using a connection to your ISP (Internet Service Provider) over some kind of line whether it is a phone line using a modem or a cable for a cable modem. ISDN is just another way that you connect to the internet. ISDN stands for Integrated Services Digital Network. ISDN is a digital phone connection system and is often used to give you higher and more reliable service. So, what they mean is to call your phone company and ask them to check your line, that is all they mean. Remember, the Internet itself is just a huge set of connections using an unbelievable number of types of connectivity from phone lines to space based relays and how you get there is through whatever line you have set up between you and your ISP. Does that help?
May 23, 2012 | Polycom Viewstation Pvs-14xx & More...
Hi I have been tasked with simple programming task on a panasonic kx-td816 ISDN phone system. Well I thought it would be simple!!. We are small company and when we are out of the office I want to set up...
Don't they have Panasonic Engineers where you are? We don't have ISDN here, but we do have things like software revisions, CF off premise, and flags in 990 and 991 that have to be turned on to forward a call to outside numbers. In our features guide, 4.3.13 Call Forwarding -- To Outside Line, there's a Conditions and Programming Guide References that tell us that you need Class of Service changes and Outside-to-Outside Line Call duration time (206 default 10 minutes) 504 CF to outside line and 601 Class of Service programs to change.
Your Mileage(Kilometers) May Vary.
Carl
Jun 25, 2011 | Panasonic KX-T7436 Phone (KXT7436000000)
I have a prostar samsung 816 plus and we have a number of phones in the office and only one is ringing, how can I make them all ring? I have followed the instructions in the manual and the following...
Hi, have you checked that the number is ringing at a group? to do this enter customer programming;
TRSF 200
1234
1 to enable
press your speaker key
enter 714
The screen will display;
DID DGT (001)
DGT : XXXXX
Press the volume key until you get to the number you wish to program, when you have reached this press the 3rd soft key under the screen (TAB) until you get to the DDI Destination which will display:
1 : XXX 2 : XXX
Enter the extension number OR the group number which you want this DDI to ring at. (1= day ring plan , 2= night ring plan, unless other ring plans are in place on the system )
Once you have put the group in you need to go to 601 to enter all extensions into that group. If you visit http://www.abbeytelecom.com there are easy to follow videos covering a wide range of programming issues on the Samsung phone systems, I have uploaded one which I think will help, regards
Apr 06, 2011 | Samsung Prostar 816 Phone
Using AVAYA IPO 500 R6 V2 IN 1616 and 1608
Check the IPO software is installed correctly and see if the most up to date software is installed, current software version 6.1 for this model.
Uninstall previous version or current version. Then Reinstall the newest version.(6.1)
Should take of any problems you are having with the phone. Since you have replaced it once, the problem lies in the software not hardware.
Mar 16, 2011 | Avaya 1616 IP Phone
I have a polycom viewstation FX and appear to have problems regarding the ISDN. We seem to be able to connect outgoing calls ok (however it does take a long time). But incoming calls do not connect, just...
How many lines (circuits) do you have going to your system? Is it possible they are out of order? Give me your ISDN numbers and I'll try to connect to you. Where are you located? My e-mail address is sducz5@aol.com
Dec 08, 2010 | Polycom ViewStation ISDN (pcy220011323001)...
Hi , i"m having problem configuring a windows
in Windows possibly in Energy Saver setting look for wake on ring.
Specs are here, although the card is actually obsolete.
Digi DataFire Micro Specs
make sure your drivers are up to date. Click drivers on this page and choose OS.
DataFire Micro
Digi Datafire Micro Google Search
May 16, 2017 | Microsoft Windows Server 2003 Standard...
Mitel SX-200 D PBX generic 1003 ACD- doesn't support ISDN.
You are not going to get the ANI information you need from the current configuration, the only way to get that information is thru the use of PRI.
Apr 08, 2009 | Mitel 9109-021-000 T1 Trunk Card (24...
I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP -PBX PHONE SYSTEM WITH PANASONIC PHONES KX-T7633 PHONES.WE HAVE NINE PHONES IN THE OFFICE AND I CAN ONLY GET 1 TO RING ON INCOMMING CALL HOW DO I GET ALL...
In program no (620) enter all the extension nos which you want to ring in group 1. Then in program no (450) enter the floating no of group 1. You will get the floating no in program no (623).
Mar 23, 2009 | Panasonic KX-T7633 Corded Phone
One line two Devices
WinFax will support two modems, but I believe only one ISDN device. So, you can't use both ISDN and analog fax modem at the same time.
Nov 24, 2008 | Symantec WinFax Pro 10.0 for PC
Lands Phones Logo
46 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
