Question about Maytag EPICz 6.7 Cu. Ft. King-Size Electric Dryer
My check lint filter light is on, lint filter has been cleaned. is the exhaust line possible clogged? I have a Epix Z series dryer, the lint filter was not cleaned and now the check lint fileter light is on. Any ideas?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
Why am i am getting lint on my wash, what can i do to prevent this? Spinning causes lots of lint to accumulated in the drum holes.
Clean your filter. Are you talking about your washing machine or dryer? If dryer, clean lint filter after every load. Also you should immediately check to ensure your exhaust hose is not clogged with lint. Also look at the exhaust opening outside your house to see any visible signs of lint. If you have lint that is accumulating in the house it can cause a fire. Check this!!!
Feb 23, 2015 | Washing Machines
Keep getting warning "check exhaust" on a new gas dryer. All exhaust is clear. What's going on?
The CHECK VENT duct blockage sensing system detects and alerts you to blockages in the duct work that reduce exhaust flow from the dryer. This light does not indicate any problems with your dryer. If this light blinks, it indicates that your home's exhaust system/duct work has a serious restriction
Every time the dryer is turned on, the CHECK FILTER LIGHT WILL BLINK, as a reminder to make sure the filter is clean. Always make sure the lint filter is clean before starting a new load; a clogged lint filter will increase drying times.
The Kenmore Elite dryer has a sensor that detects poor exhaust venting, and when it does, a light flashes on the control panel. This warning light does not include a mechanism to stop gas flow, but if it is allowed to flash for an extended period, poor venting may cause the dryer to overheat. As a result, a fuse might blow and disable the gas valve or ignitor. You can prevent this by diagnosing the reason for the flashing indicator light as soon as possible.
In many cases, LINT has built up somewhere in the exhaust pipes.
Check under the lint filter. Pull it out,look inside the slot it fits in, and clear all lint from this area.
Is it possible you have used the WRONG VENT MATERIAL?
Check your vent to make sure it is 4 inch rigid or semi-rigid metal ducting. If your venting is plastic or flexible foil, replace it before using the dryer.
Check your vent hood outside. You may have a restricted or damaged vent hood. It must be clean and free of lint buildup. Check the damper and make sure it opens fully and easily and is free of lint.
I know you said you have no elbows, but I have posted the pipe run lengths with and without elbows. Keep in mind this is with 4 inch rigid or semi rigid metal ducting.
Measure the length of your exhaust system and count the elbows. Use the chart below to see if your duct is too long. If it is too long, have the duct routed to another location that is within the venting guidelines.
0~90 degree elbows=65 ft of 4 inch rigid metal duct.
1~90 degree elbow=55 ft of 4 inch rigid metal duct.
2~90 degree elbows=47 ft """"""""
3~90 degree elbows=36 ft """"""""
4~90 degree elbows=28 ft """"""""
You should always use duct tape or metal tape on all joints, NEVER USE SCREWS, as screws capture lint inside the pipe.
One more note. Lots of people overlook the fact that fabric softeners can build up on the lint filter over time. This buildup can restrict the airflow through the filter reducing dryer efficiency and lengthening drying times. After removing lint, if the filter looks dark or dirty when held up to the light, follow these steps to clean:
Use hot soapy water and a stiff brush to clean
the filter.
Make sure the filter is completely dry before
reinstalling it and using the dryer.
NEVER operate the dryer with a wet lint filter.
Oct 29, 2014 | Kenmore Dryers
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
Always air filter clean
If the light comes on after it\'s started its cycle, that sounds like your dryer actually has a sensor in it (my dryer just has a fake light to remind you to clean the filter, but there\'s no sensor).
Either there\'s debris accumulated inside that\'s blocked the sensor (it\'s working correctly), or the sensor itself has failed (part repair).
It\'s possible your filter itself isn\'t letting enough air pass through any more. Do a quick test: run the dryer with the filter out and see if the light still comes on.
If the light still comes on, see if you can remove some lint from the dryer. Remove the filter and get a vacuum nozzle in as far as you can to try to suck out any lint that got past the filter.
Also check the exhaust. How recently was your dryer duct cleaned? Could it be clogged? Disconnect the exhaust from the wall and inspect the pipe. If you see a *lot* of lint and dust it should probably be cleaned. It\'s not expensive - call a duct cleaning company and ask them to clean your dryer duct and nothing else. No addons, no extended service plan, nothing - just clean the duct.
By now you\'ve checked the air going in and the air going out. If it still continues this behaviour I would look at the sensor itself. It\'s almost certainly cheaper in the long run to call in a repair person for that.
Mar 03, 2014 | Dryers
I HAVE A KENMORE 400 SERIES DRYER. THE LENT NO LONGER STICKS TO THE FILTER. WHEN I PULL THE FILTER OUT TO CLEAN IT, THE LENT SLIDES OFF THE FILTER CONTINUALLY CLOGGING THE VENT IN THE BACK OF THE DRYER....
Try cleaning the filter to remove any residue from dryer sheets (a dish detergent solution should cut the softener build-up). Be as gentle as possible. An old toothbrush is useful for this.
Also, a weak exhaust flow may be the culprit. Check the dryer vent line all the way outside for excess lint.
Your fan impeller (inside the dryer) may be loaded with lint, too.
Apr 29, 2010 | Kenmore 400 6943 Dryer
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
DRYER KEEPS OVERHEATING AND SHUTTING OFF MAYTAG SDG305DAWN.
Have you checked yout exhaust? It must be clear and clean. If it is a plastic hose, you should consider replacing with with a flexible metal hose. Dont forget the part outside.
You should pull the machine away from the wall, remove the hose and turn the machine on. Use the AIR setting. You should experience a strong flow of air. If not, there may be a clog between the exhaust port and your lint filter.
There is the possibility your machine is clogged between the fan and the drum. If you open this little space, remember the parts you find inside are powerful yet fragile
If you do have strong air at this point, reattach the hose. Go to the other end of your hose and repeat the experiment. Look into the hose - if possible, run something though it to assure it is clear and clean. If you get good flow there, inspect the device that takes your exhaust to the out of doors. If that device is clean and clear, it may be time to call a pro to look at your machine for malfunction.
I hope this helps you.
a
Sep 27, 2009 | Dryers
My maytag dryer runs and there is some heat ,but clothes take hours to dry
Check dryer exhaust force at outlet. The exhaust should exert strong pressure against your hand. If not clean or replace vent system.
Dryer lint screen may be clogged with lint or finely pulverized detergent residue.
Another possibility is that the operating thermostats may be out of tolerance.
Hope this helps.
Aug 24, 2009 | Dryers
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Nov 20, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Maytag EPICz 6.7 Cu. Ft. King-Size Electric Dryer Logo
3,329 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
