Question about Dometic Rooftop RV Air Conditioner
I just bought a 1990 pathfinder motorhome and we had the air on.It started to storm really bad and the storm knocked the power out.We checked the breaker box.And it still won't come on..Can someone help us please..
    President:
  • 1,515 Answers
Hi, if a storm knocked the power out, I don't believe it caused damage to the unit. If you are sure the breaker is fully re-set and you have power to your a/c, go to the condenser on the roof. You will have a disconnect box which should contain 2-fuses. These fuses may have blown causing your problem. Please replace both of them as one. This will restore power back to your a/c and be back in business. If this is not the problem, please contact me and we can go from there to get this solved. Please keep me in mind when rating me, please be kind as I am sure you will. I wish you the best. Keep me posted PLEASE!!
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jul 30, 2010
3.0l. What is causing knocking?
If the code is p0325, it should be repaired, HOWEVER, on nissan products from 1996 to 2002, a p0325 does NOT illuminate the check-engine lamp. Knock sensor on that vehicle is for PING control not for emissions reduction. On other vehicles (say a chevy with a p0325) it WILL light the check engine lamp which is an automatic smog fail.
Jan 16, 2016 | 1995 Nissan Pathfinder
My 1990 pathfinder idles fine but as soon as you give it gas it starts to die , any ideas?
Sounds like you have a dirty Mass air flow sensor...it is located mass air flow tube.( main ) air intake..try some cleaner made for it..or go to a auto parts site like auto zone and see what years and models it fits many have the same that interchange...being a 1990 you should be able to find one at your local salvage yard for a reasonable price,,new ones can get pricy...it is an easy off and on job..good luck..
Sep 30, 2015 | 1990 Nissan Pathfinder
Geo storm wont start after putting in new battery,altornatior,plugs and wires,and cap and rotor
storms, those are very rare. and Isuzu is very dead here.USA.
which size engine?
wont crank/?
or cranks ok, but wont start.
its old.
1:check compression, yet, over 150PSI (w.o.t)
2: check for spark at all 4 cylinders?
3: try test fuel if spark is good (spray fuel)
watch scotty
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
tell us how far you get.......
btw , it really a:
manufactured by Isuzu and sold in the United States by General Motors from 1990 through 1993 as part of GM's Geo line
btw2
1.6L DOHC (Storm) Interference
both DOHC engins are interfernance
if you skip belt changes, the valve bend and bye-bye engine.
BOOM
and a new motor is more that car is worth.
Feb 18, 2014 | 1992 Geo Storm
Whats next , wires ?
Need a fresh start at a repairs shop
Was no need to install any of those parts
You needed to diagnose any and all issues
first,then come up with a solution to repair
Jul 24, 2013 | 1990 Nissan Pathfinder
1990 toyota 4runner knocking noise from air intake will turnover but wont start
Knocking noise in the air intake or do you mean a lifter noise,because you let it sit the lifter are not charged up or solidified,so you dont get adequate compression when you turn it over.if you have fuel and spark thats fine what about compression,noise from the air intake make me wonder if the timing belt is intacted.
Feb 04, 2013 | 1990 Toyota 4Runner
Getting codes P0325 and P0420. Where to start?
code P0325 is for knock sensor and it looks like is a common problem with these engines.You might need to replace the knock sensor, and this is a few hours job for a qualified mechanic.You can try first using a high grade gasoline, but I doubt it will fix the problem.
code P0420 -right bank -B1 three way catalyst function.
possible cause for P0420:
-you might have a hole in the exhaust tube
- you might have some intake air leaks
- injectors leaks
-spark plugs
check first for some damage exhaust tube.or it might be related to code p0325, as a change in timing dictated by knock sensor malfunction.
hope this will help.
Good luck.
Jan 23, 2011 | 1998 Nissan Pathfinder
1990 geo storm wont start, no fuel, no stored codes.
can you hear the fuel pump when you turn the ignition key to start position??( you should hear it start then stop after few sec.) If not, this could be the fuel pump fuse,some bad contact in the wiring of the fuel pump or the worst case the computer.but if you do,unplug your main fuel line to the injector turn the switch to start position again to see if you have some fuel coming out.if not this could be the fuel filter or the fuel pressure switch! hope this will help you...lipak!..
May 05, 2010 | 1990 Geo Storm
Ford F150 engine backfiring, running/idling rough
I Have a 1999 ford f150 4.6 that back fires and is just running really ruff when idling alot of nack fire a sord of like a pulse going on what is my problem?
Apr 16, 2010 | Ford F-150 Cars & Trucks
Strange smell after car drives
If it smells like rotten eggs or simular then its usually the cataletic convertor (sp) and another way to check is if it is starting to go bad it will get really hot. What it does is over a period of time will plug up and when it starts it restricts the airflow causing it to het up and sometimes even start glowing it gets so hot. Hope this helps.
Mar 25, 2009 | 1990 Nissan Pathfinder
Air will not come on
hmmm..sounds like an amperage issue..what's the rating on those units. other thing..is plugging in at your place, is most likely hitting an invertor, which needs enough juice on back end to power those..check with the previous owner to determine what they did
May 31, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
129 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
