Question about Air Tools & Compressors
Atlas Copco Air compressor wont start and throws power out!
Have a Atlas Copco air compressor and i turn it on and it just tries to start and throws the power out, the motors not siezed as the generator and motor turns around OK. Thanks
  • sjbrewy Jul 31, 2010
    I ended up getting it going as i pulled and reconncted all the spade joiners on the smaller cylindrical tube (couldnt do it to the capacitor-larger tube- as wires are soldered), and wire joiners in the electriclal box on top of generator and the pressure switch that turns it on and off with air pressure level and to my suprise its working fine, tried it about 6 times and good, so one of the wires must have needed reconnecting, they were all on there good but must'nt have been making good contact.
    I got it going, i disconnected/reconnected all spade wire connections from the other cylindrical tube above capacitor, couldnt do that one as wires are soldered, did wires on electrical box on top of generator and the air pressure switch and to my suprise it works OK.
  • 553 Answers
If your problem is only when there is pressure in the tank you most likely have bad pressure relief valve. If you drain the tank and it starts then you just need to replace the pressure relief valve.
If it happens whether you have pressure in the tank or not you most likely have a bad starting capacitor. If you have a motor repair shop near by it should be a fairly inexpensive repair. If you've ever run the compressor on an extension cord this is the most likely problem but it is possible you burned out the starter windings. The motor repair shop can tell you rather quickly which it is. If you don't have a motor repair shop near by you can order replacement starter capacitors from Graingers.com be sure to give the length and diameter as well as the capacitance.
Posted on Jul 30, 2010
  • 1 more comment
  • sjbrewy Jul 30, 2010
    HI,
    It does it air empty or full, which ones the starter compaciter, as on top of the generator part there is a square box and of the side of it are 2 cylindrical units, the top ones a bit smaller than the other. Thanks
    Did you get my responding question.
  • jonesspammai Jul 30, 2010
    No, I didn't get your message, the larger capacitor should be your start capacitor.
Compressor motor converter failure for compressor GA315VSD
if it is this unit this link may help you
http://www.about-air-compressors.com/atlas-copco-compressors.html
or try this one you tube link
https://www.youtube.com/watch?v=QUj-mrzxS4o&ab_channel=ChouseMolla-Storm
How to reset Atlas Copco Electric Air Compressor
Sep 17, 2017 | Air Tools & Compressors
We want a control panel Part No. 1604 9422 02 Xc2002 for our atlas copco air compressor XAMS 850 CD7. Can you help us on that.
we don't sell parts for anything
contact your atlas copco service center for the parts or get them from e-bay
Sep 20, 2016 | Air Tools & Compressors
Where do I get a spare parts manual for a Atlas Copco xas 160
The staff at www.aircompressordelmarva.com has all the manuals for atlas copco air compressors. You can email or call them. They posted an Adobe link for me for a really large one so I could download it. Very helpful. Delmarva Air Compressor Powered by Network Solutions
Nov 15, 2014 | Air Tools & Compressors
Atlas copco troubleshooting
If pressure on display is higher than set pressure of your safety valve,then your safety valve is doing its job. If pressure on display is lower than set pressure of your safety valve,then your safety valve is defective.
Aug 06, 2014 | Atlas Copco GA Rotary Air Compressor...
I need a service manual for a atlas copco xas85dd 175cfm air compressor
necesito el manual de atlas copco del compresor de alta presion xas 175
May 28, 2011 | Air Tools & Compressors
Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Air Tools & Compressors Logo
309 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
