Question about Rocky Mountain Hardware Shower Curtain Rod and Brackets w/ 12 Hooks
I PUT UP A CURVED CURTAIN ROD. IT KEEP CUMMING OFF THE WALL
    Scholar:
  • 67 Answers
These rods need a little more support than a standard rod because of their shape. I'm assuming you used a plastic wall anchor in the gyproc or plaster. If so get rid of it and use a butterfly style anchor. The butterfly provides superior support and will allow to tighten the screws more tightly than with the plastic wall anchor. Good luck with your project and let me know if I can be of any further help.
Posted on Jul 30, 2010
Which type of beaded curtain should I purchase for a wedding?
ok what is the application for the curtain.
it all depends on if its a gift or to decorate the room. just go with the one that you like. if its a gift keep the reciept if you can return. or get a box and put a note her is your new curtain and a gift card etc.
Dec 09, 2017 | Clothing
I purchased a 48" curved
you will need to buy an anchor kit at a discount store(K-mart, Walt-mart, Magic Mart,etc) or a home improvement/hardware store. The kit comes with anchors,screws and a mason bit. with the help of another person figure out where your anchoring hardware is going to be mounted, mark the holes with a Sharpe,pencil,pen,etc. drill holes,lightly tap in anchors until they are flush, secure mounting hardware and hang rod. hope this helps Tim
Mar 15, 2011 | Home
Crescent rod installation into a acrylic walled shower/tub unit. instructions say differant hardware needed but not included,consult contractor or hardware store for installation.
You will need to seal any holes made in your acrylic walls inside your bath unit. When installing the brackets to the wall, try using a piece of rubber (pre-cut for a custom look) between the acrylic wall and the bracket mounting hardware. Be sure to seal everything with a clear latex caulk that is designed to resist mold.
May 08, 2010 | Crescent Rod The Rod - 5' Curved Shower...
Adjustable (tension) shower curtain rod too long
Yes you can ! You only have to pull off the rubber end cap and cut it , file off ant burrs. Cut the SMALLER diameter end only, the other end contains the spring !
Nov 16, 2009 | Rocky Mountain Hardware Shower Curtain Rod...
Screechy shower curtain
what I would try is putting a strip of glue from a glue gun. It is barely noticeable. But us enough to stick.
Apr 12, 2009 | Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x...
they do make chrome plated, plastic curtain rings.
Apr 12, 2009 | Home
How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
Apr 04, 2009 | Home
Polder Duo Shower Curtain Rod Instructions
Cindy,
This might help you out.
http://common.csnstores.com/common/marketing/uz1194manual.pdf
Feragola
Nov 22, 2008 | Home
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
Rocky Mountain Hardware Shower Curtain Rod  and Brackets w/ 12 Hooks Logo
139 people viewed this question
Top Rocky Mountain Home Experts
john h
Tom Chichester
Are you a Rocky Mountain Home Expert? Answer questions, earn points and help others
