Question about Kenmore HE3T Washer
Control lock light wont go off cant wash or anything even tried to unplug
NOT WORKING
Posted on Aug 18, 2010
  • 5,081 Answers
Press and hold 'dry' & 'spin' that should unlock OR Try holding the "end of cycle" button down for 5 seconds.
Posted on Jul 30, 2010
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
I have a Frigidaire (ATF6000ES) Front Load Washer all lights come on and wont work.
Sounds like either the control board is faulty or the door latch sensor is not allowing the control board to communicate to the rest of the unit.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
There are 2 dashes in little window and the control locked light is on but the machine wont do anything i have tried unplugging it but cant find the manual to reset it if thats what needed
Push & hold the “end of cycle” for 3 seconds. I am pretty sure it is written right beneath the button. (electronic timer) This would be the lower right hand button held down for 3 seconds.
Thanks for using FixYa.
Kelly
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my washer won't lock!
the door lock has internal relays, if they go bad, the motor control board will not function. Even if you cant physically see anything, and even if the door still locks, the door lock assembly is still the most likely problem and needs replaced. The only way to test it is with a multimeter to know for sure before you buy a new one
Oct 19, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Control locked light is on.
The procedure for clearing this is to press and hold the "end of cycle" button for three seconds. It should be all the way on the right of the panel. Let's try this first. before we look at anything else. Hope this helps and let me know what happened. Good luck.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light on
Try holding down the end of cycle button for at least 3 seconds.
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked onHe3
try unplugging then hold power button down for 10 secs or so with power removed this may help reset the control bd may even try holding lock button down longer than 3 secs i usually hold until light goes out
Jun 25, 2008 | Kenmore Elite 45986 Front Load Washer
Door lock light flashes, I had a power cut earlier which interupted the cycle, any ideas?
Power interuptions are never good. If all your controls work and the door wont lock you are going to want to replace the door switch or latch whatever your manufacture calls it. Unplug it wait fifteen minutes (make sure door is shut) plug it back in (also reset breaker is cant unplug) if this dont fix it, either a control board short, easiest and cheaper repair is door switch/latch
May 01, 2008 | Washing Machines
Flashing Control lock light
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Apr 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore HE3T Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
