Question about Bosch Dishwashers
My dishwasher has a white film at the bottom after each cycle and the dishes are starting to have spots. Help!
  • alisonstewar Jul 30, 2010
    dont know what you mean adrian
    Genius:
  • 1,075 Answers
Cheap salt/no salt.adrian,,,
Posted on Jul 30, 2010
Frigidaire d. w. grit and white film on glasses
Good Morning Friend,
I see that you are receiving grit and a white film on your glasses, in your Frigidaire dishwasher, model# FDB1050REC. Here are some common solutions that you can begin with.
-Check your water hardness. Hard water can cause lime deposit buildup on the interior of the dishwasher. Dishes and glasses may also get spots and film for a number of reasons. To remove buildup, spots and film, clean using the following instructions:
1. Load clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes).
5. Unlatch and open the door, and pour 2 cups of white vinegar into the bottom of dishwasher.
6. Close and latch the door and allow the cycle to finish.
For extremely hard water, it may be necessary to install a water softener.
-Your water temperature may be low. Avoid extremely low or high temperatures.
-Avoid overloading and improper loading.
-Make sure you are using fresh detergent. Old detergent is ineffective.
-Make sure your rinse aid dispenser is filled.
-Check to see that the proper amount of detergent is being used for cycle selected.
-Your home water pressure may be too low-it should be 20 to 120 pounds per square inch (psi).
If none of these suggestions helps, I would suggest contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 16, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Nasty white residue left on dishes at end of cycle, and dishes not cleaned
The ****, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and **** in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 23, 2011 | Kenmore Dishwashers
White film on all dishes after running the cycle
heatman101
Aug 04, 2011 | Dishwashers
Our maytag is about ten years old. No big problems that a little vinegar wouldn't solve once in awhile. Lately, we ran out of water softener salt and a white film was on dishes and not getting clean. I...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 28, 2011 | Maytag 24 in. MDB4100 Built-in Dishwasher
Kenmore Ultra Wash dishwasher leaves spots on ALL dishes, top and bottom. Changed detergent, same problem.
heatman101
Feb 24, 2011 | Kenmore Dishwashers
Dishes are still dirty at the end of the cycle
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
The dishes have food residue washed onto them and water spots on all glasses regardless of the amount of detergentinse agent. The pump seems fine there is no water left in the machine after a cycle. any...
heatman101
Jun 28, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
White residue left on dishes; Plastic ware being oxidized
heatman101
May 10, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
My dishwasher is leaving residue or soap scum on my dishes...
heatman101
0=0
May 02, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
A white nasty film on the dishes after washing
Check to make sure there are no bits or trash or paper around the bottom parts of your dishwasher. Place a bowl of vinegar on the bottom rack of your empty dishwasher. Run your dishwasher through a complete cycle.
Mar 23, 2009 | Dishwashers
Dishwashers Logo
47 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
