Question about Fisher and Paykel DE09 Dryer
No heat on any settings...worked the day before...great dryer, but less than a year old. What's up?
  • Fisher and P... Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
My dryer is not rotating, heater is working. It is
sounds like a belt and the heating eliminate
Sep 26, 2009 | Dryers
Dryer Stopped Heating
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Jul 28, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer-Mod.#11066514694-won't spin or heat
This could be caused by an internal thermal overload switch. These usually have a limited life span in any appliance that uses heating elements. Try to locate the overload switch which usually looks like a small diode or resistor. You can determine if this is the cause by bridging the switch with a piece of wire, then trying the dryer once more.
Best wishes,
Graemevm
Jun 06, 2009 | Dryers
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer has no heat on any setting after house fuse blew.
We got the problem with our dryer figured out. After checking possible solutions on-line, we checked the power going into the dryer with a ohm tester and discovered we weren't getting full power that we expected. Just after changing the fuses in the house the first time we heard a snap sound but the fuses appeared to be fine, but no heat to the dryer. When we discovered we weren't getting full power we used the ohm tester to test the fuses indiviually and discovered one of the fuses were bad. Put in a new fuse and wala! the dryer is putting out heat. Thank you so much for the service you provide to "do-it-yourselfers" like us!
Nov 10, 2008 | Dryers
My dryer is just blowing cold air, it is not heating. It is less than a year old. We just moved and it is not working now?
call whatever brand it is and have them send somebody out there. if its less than a year old its underwarrenty
Aug 05, 2008 | Whirlpool Dryers
Fisher and Paykel DE09 Dryer Logo
143 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
