Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Replaced bulb on panasonic projection tv and the tv still wont work. is it a ballast problem?
spqr163
  • 37 Answers
SOURCE: where do iget a ballast for a panasonic pt50lc14?
my recomendation would be save your money, and spend it on a new tv. by the time you pay for it you could of bought yourself a new tv...even though it wouldn't be a 50" you'll be much happier in the long run.........
Posted on Mar 12, 2009
welcomejee
  • 10594 Answers
SOURCE: my panasonic rear projection pt-52lcx65 wont turn
Sounds TV needs Ballast Supply board replacement, it is available in Part Store.
If you wish to replace above board by yourself, should have service manual copy that is available HERE for small fee.
Or call local TV tech for fix.
Thanks.
Posted on Aug 06, 2009
  • 556 Answers
SOURCE: is the ballast on the panasonic 52lcx66 a one
The ballast is seperate from the light engine it is a circuit board.
Posted on Oct 28, 2009
ArnelM
  • 184 Answers
SOURCE: Looking for part number for the ballast in a
Part# LSEB3087A
Posted on Dec 26, 2009
SOURCE: panasonic projection tv model # pt56lcz7 no picture, bulb out?
My system is doing the same thing... runs for ten minutes an then no piture and no sound, I just get a blinking green light.
I was thinking heat was the problem, I opened it and vacumed it out. This did nothing.
Now , is it the powersupply or the lamp? Would a bad lamp also cut the sound?
Randall
Posted on Jan 16, 2010
New lamp worked for 2 weeks, last night would not turn in so removed lamp thinking it was burnt to send back under warranty. Lamp appeared fine so reinserted and tv surprisinly turned on. this morning...
Edwin, sounds like you might be having a problem with your Ballast. The Ballast is what fires up lamp. Typically if this is an older unit, when you replace the bulb, you will have to replace your ballast as well. It is harder to fire up a new bulb, then it is to fire up an old bulb. That's why you wouldn't notice the problem until you changed your bulb.
Mar 01, 2014 | Panasonic Televison & Video
Bulb or Ballast?
If your old lamp is still working fine and the new lamp is not, then you bought a defective lamp. Get your money back or exchange the lamp.
May 17, 2012 | Panasonic PT-52LCX66 Projection Television
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic rear projection pt-52lcx65 wont turn on replaced the bulb now what antbody ?
Thanks.
Aug 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Where do iget a ballast for a panasonic pt50lc14? already replaced bulb, looking for a ballast. is there a spacific ballast i need?
Mar 02, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic TV pt-50lc13 bulb replacement
Take the bulb out, there should be a access panel in the front, power the set on,(be sure to have the lamp door closed) if you hear a rapid ticking noise from the set, the Ballast is trying to fire the lamp, this is a good indication that the set is functional but the lamp needs to be replaced. If not, the ballast is not getting the voltage needed to start the lamp.
Sep 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
Feb 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp will not light
At first i was thinking the ballast had gone bad but after reading a few other post i think it would be best to call pannasonic..
others forums read:
ballast had gone bad. Panasonic no longer makes these ballasts so mine needed to be rebuilt at the tune of $400.00.
With the ballast in place still nothing so now they claim that they need to order a "kit" from Panasonic which basically is all the components of my tv.
Jan 28, 2008 | Panasonic PT-40LC12 40" Rear Projection...
PT 50LC13-50 Panasonic TV
Going through bulbs that quickly would indicate to me a problem with the ballast or smps (switch mode power supply). It's not something you want to just run out and replace (expensive).. Call a reputable shop and tell them what you're experiencing.
I do know that they should check the value of C1330 in ballast circuit. If it is a .22uf, There is an upgrade kit available for it, panasonic p/n# LSUC0022
Nov 05, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
249 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
