Question about GE CleanSteel GSL25JFTBS
The fridge side is not getting cold even when temp is turned up. freezer side seems to be maintaining (things are still frozen)
  • GE Master
  • 17,130 Answers
It is possible that the air blowing of the fan is restricted due to freezing within the cooling coils, frost developing too much inside the coild, This can happen even if the door had been kept too long open or if the auto defrosting of the fridge is not working fine. So first of all deffrost off the fridge totally by shutting it off for about 8 hours. Clean up totally and restart after you think the cooling coils are clean and dry. Now check for the first 24 hours how the efficiency of the system works, is it better or worse or the same. If better it is sure you auto defrosting is not working and you will have to check up on the auto timer unit. If the same then check the speed of the fan and the blowing, set the temp in moderration to the freezer and the fridge to balance off, not too much for the freezer and try. I am sure the fault will be in this section. Hope you try this out. Good day
Posted on Jul 30, 2010
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
We had a power outage, after power back up, the fridge is getting super cold, milk is frozen, we make the fridge temp higher, doesn't help
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
We just moved into a home with a 3 year old GE side by side refrigerator (model# GSS 25LGMB BB, serial# VA 412740). It works but it's not as cold in the fridge section as it should be and we have it on the...
Ok, this is a temperature control board malfunction. this board control the temp throughout the box and , if it is unstable and unable to regulate the temp, it will produce erratic fluctuations within the box itself. simply replacing this board will fix this issue.
CLICK TO PURCHASE THE TEMP BOARD
Please rate and god bless:)
May 11, 2009 | Refrigerators
Fridge seems to require max cold temp control
did you check to be sure the the compressor cooling fan is operational? if this is bad it will cause a problem similar to your condition. another thing if this checks ok is that your temp control could be getting weak, ( it has small springs connected to the contacts) and may need replacing. the fact that it will get to 0f tells me that compressor and freon system should be fine.
you mentioned the warm area on the side of your door is a anti moisture feature. if this area is abnormally hot it would indicate a bad condenser fan motor which is the compressor cooling fan.
If you have any further questions let me know thanks Peyton
Feb 23, 2009 | GE GSS20IETCC 20.0 Cu. Ft. Side-By-Side...
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Freezer does not seem to keep things frozen in my refridgerator .
probable reason for this is that the thermostat controls freezer temp and freezer follows suit.
if temp in your garage is low ie in winter, then the fridge doesn't need to switch on and the freezer temp rises.
i know this sounds barmy but it is true
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
GE CleanSteel GSL25JFTBS Logo
164 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
