Question about Whirlpool Duet GHW9150P Front Load Washer
Can we fix the pump switch when we are consistently getting the F35 code?
  • 5,081 Answers
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
Posted on Jul 30, 2010
Error code f35
F35 (on some models)
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 19, 2011 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer is about 2yrs old. I am now consistently getting either "Sud" code or F35. Is there a part for the F35 that needs to be replaced? If yes, could you let me know as well as...
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite washer he3t model 110.4674 and the error code F35 keeps coming up. We did clear out the bottom drain pump, which had a lot of debris including toys, socks...etc. How can I clear the...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^##
Jun 10, 2010 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@$$
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
F35 on whirlpool duet ht, tech came out and reset board a few days back...same problem again this morn....talking about a switch. Can you Help
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Aug 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sears Kenmore HE3 Error Code F35
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
142 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
