Fellowes 420HS paper shredder "cabinet door ajar" red light is on and will not run forward (cabinet door is closed). I jumpered the wires to the door switch but that made no difference. It does run in reverse. Thank you. Mac
    President:
  • 739 Answers
Do you mean Fellowes 420HS paper shredder machine?
most likely you need to undergo a more detailed inspection for your machine, I recommend you based on this manual to identify the problem.
Click link below to view
http://www.fellowes.com/Fellowes/Materials/Documents/420_420cc_420hs_1999manual.pdf
thanks
hopefully this can helped
Posted on Jul 30, 2010
  • mrobinet470 Jul 30, 2010
    I already have an operating manual. I need a technical manual with the schematic. The "door ajar" red light and the "forward run" green light are both on at the same time.
    The shredder has a PSC motor. I confirmed that the problem is not with the motor because it runs forward if I interchange the motor coil which is connected to the start capacitor. This, of course, bypasses all of the automatic and safety features.
    Thank you,
    Mac
My fellowes ps-70 shredder has a light on and it's not working
If the shredder is the kind that turns on when you insert paper, it may have an optical sensor that is dirty or blocked. Try blowing off the sensor with some canned air. The sensor is usually located in the center of the paper path slot. Also check that the bin is completely closed. Sometimes a tab on the door is bent or broken so that the shredder thinks the door is open. The tab activates a switch which tells the shredder that the door is safely closed. Fellowes has a lot of good tips on their website.
Apr 22, 2014 | Fellowes PS70-2CD Shredder
Shredder keeps stopping and the bag is not full
there are three switches on most shredders that can cause them to stop.
1) a jam
2) door ajar
3) bag full
If you can rule out a jam, and the door ajar light goes on when the door is open and off when its closed, and the shredder has not been undergoing very heavy use (they will overheat and shut off, then be fine in 15 min or so)
then its a safe bet to say that it has to do with the switch that tells the shredder that the bag is full (when you take out the bag you can see a metal flap hanging down at the back of the top opening)
the way that the shreddings fall can often trip the swtich that tells the shredder that the bag is full, shake the bag a bit so the paper resettles that often fixes it.
Nov 08, 2011 | Fellowes Office Equipment & Supplies
Paper gets jammed. Even shredding just one sheeet of paper. Clicking noise is heard before the red light comes on.
The problem was solved by putting some oil on the top of the shredder and running the motor forward and in reverse to coat the teeth. Thank you.
Oct 16, 2009 | Fellowes DM8C Cross-Cut Shredder
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
Basket ajar light stays on even when the door is closed. How do we get the light to go out?
The door sensor could be bent or broken. There is also a thin piece on the door that pushes the sensor switch. Check to see if it is broken. Try pushing a thin object into the sensor **** opening and listen for a click.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 18, 2009 | Fellowes Powershred 120C-2 Shredder
Fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Oct 22, 2008 | Office Equipment & Supplies
Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
Sep 06, 2008 | Fellowes Powershred 480 Shredder
Red light on will not run in forward
Check to make sure the shredder is sitting on the paper bin properly. Most shredders have a sensor switch that disables the unit if it's not properly seated on the paper bin.
Jan 21, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
Marvin
Marvin
