Question about Dell (E210882) Motherboard
My computer acts like it's overheating, however I can feel my fan working normally. The computer will run for about 5-10 minutes, then freeze up, at which point my screen will lock but my computer will go silent (eg fan will stop running). At this point, my computer gets very hot, and then it goes to the blue screen, or just completely shuts down. I'm wondering if there is something wrong with my motherboard or anything else internal besides the fan. I am not terribly computer intelligent, and would just like some additional input. Thank you.
This problem happened to me. The thermocouple that senses the CPU temperature had gone bad. I replaced it and the computer works as it should.
Posted on Sep 21, 2010
Why is my A/C condenser compressor overheating, causing compressor to turn on and off every 4 minutes?
THERMOSTATE SIGNAL SHOWING OVER HEATING AND NOT RUNNING NORMAL ,HENCE OVER HEATING TRY CLEANING MAY HAVE DUST OR IT COULD BE THERASTSATE TO CONTROL AIR TO COOL
Apr 27, 2015 | Heating & Cooling
How do you stop a laptop from shutting down?
When the overheating issue is fixed, the laptop will reset. Did you clean the radiator? Is the fan running?
Oct 09, 2014 | Computers & Internet
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
I have an acer aspire ax5900. The video card fan vibrates loudly for the first 10 minutes after start up. I am told I need a new video card. Is this correct and where is the best place to get one?
Normal Operation
Troubleshooting
Solution
Radiator fan blows when motor off
Does it stop blowing after a couple of minutes? Are you overheating? Check you coolant level and make sure you are running the right mixture of anti-freeze, Is t-stat working?
Apr 15, 2013 | 2001 Jeep Cherokee
Turning off in 2 minutes automatically
My guess is that the fans inside the computer have stopped working, thus leading to the overheating. AMD processors generally run "hot" (50 to 60 degrees Celsius) even with proper fans.
Take your computer to a qualified technician, for a cleaning, and proper trouble-shooting, and repair, before the overheating causes permanent damage.
Jul 27, 2010 | HP Compaq Presario 2100US Notebook
Asprie 3690 acts like it overheats, has no battery life unless plugged in, going to order a new one. but runs really slow on start up and shut down and through out programs. Can hear fan running, then...
The overheating is causing this. Still, if you think that battery is doing that, take off your battery pack and turn it on with the adapter only.
Overheating is a very common problem with notebooks, To solve the overheating problem you will have to clean the heat sink and the fans of the laptop.
If you need assistance on how to clean the fan and the heat sink, please comment and I will be there to help you out.
Apr 11, 2010 | Acer Aspire 3690 Notebook
It has problems getting it to turn on.. and when it does turn on, it suddenly turns off by itself after 10 to 15 minutes
It could be overheating (due to the failure of a fan inside the laptop) causing the computer to "self-protect" by shutting itself down.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air.
Use the air to give a "blow-job" into every air-port in the laptop -- a layer of dust will act as a layer of insulation, preventing the computer from radiating the build-up of heat.
When you turn the computer on, listen for the fan(s) to start running -- put the hairs on your arm near an "exhaust-port" on the PC, to feel if the fans are blowing air out of the laptop.
Apr 08, 2010 | Toshiba Satellite M45-S265 Notebook
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
My Dell C640 laptop freezes normally just some few minutes after booting
When the laptop freezes up on you does the keyboard or anywhere on the top cover feel very hot if so check to see if the fan is even blowing, if it is blowing then its possible there is dirt on the heatsink fan that is blocking the air flow and thats causing the overheating. You would need to take apart the laptop to get to the cpu heatsink to remove all the dirt.
if the fan isn't running at all then you would need to get a new fan.
If the fan is running and there is no dirt or debris near the heatsink then that means the motherboard is not reglulating the voltage properly and the motherboard needs to get replaced.
if nothing is feeling very warm or hot to the touch and the system is locking up then the hard drive may have bad sectors and the hard drive would need to be replaced.
May 15, 2009 | Dell 2.8 GHz Second Processor for...
Dell (E210882) Motherboard Logo
112 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
