Question about Amana NDE2335AY Electric Dryer
Wiring diagram for Amana LEA30AW needed... Can't remember what wires attached to what...
2 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: replacing a pigtail
You hook the Red and Black wires to the gold colored screws on the dryer, and the white wire goes to the siolver colored screw. The Green wire goes to the Body.
Posted on Sep 28, 2007
On the amana LEA30aw which wires go where on the heating element?
There is usually a schematic pasted to the inside service area unless it fell out. Read it & start tracing wires. The power to the element should pass through a fuse, a thermistor(cycles power on and off relative to heat and a safety switch that kills power if it gets too hot. Don't take short cuts.
May 14, 2015 | Amana Dryers
Do you have an amana ptac wiring diagrams?
Sounds like you need a new control board.
Sep 03, 2014 | Amana PTC124E50AXXX
I have a 1997 Amana dryer model LEA30AW. On a full load it will overheat and shut off. I have cleaned the filter and the vent but don't know how to open it to clean the internal components. Can anyone...
Not sure of your particular model but most dryers you will need to use a wedge, flat blade inserted between the lid and front cover which is normally held together with spring clips. By applying pressure to each corner you should be able to release the front from the top. After cracking open the casing there will be small hex screws located on the inside of the cabinet which holds the front panel to the side panels, normally 5/16" heads. After removing screws the front, or door panel, should be able to be removed by grasping both sides of front panel and pulling up, this should release it from the bottom slots of the base and lift away. Beware of the electrical wiring and switches. Some units also have hex screws in various locations and also you may have a split or two part front assembly which means you'll have to beware of the door springs but are easily removed. just keep track of how they are attached to the frame work, not hard just take notes and this should expose your heat chamber on the left side of interior cabinet. Be 100% sure you have disconnected power from unit. For a thorough cleaning I always remove the drum so as to reach all areas of the interior. If doing this it might be a good time to inspect your drum belt for wear for as this is an excellent time to replace. Just a side note dryer assemblies usually break apart with little resistance so if yours seem to be a little difficult look for a couple of more screws in the door area attaching the door to the bottom panel. Again you will have switches and wiring going to the door assembly.
I'm attaching a link which I use quite often, hope it helps.
http://www.appliancepartspros.com/01-cabinet-base-parts-for-amana-lea30aw-plea30aw.html
Aug 20, 2013 | Dryers
I need to know what is the correct wireing for a amana dryer element model LEA30AW
There are two wires that run into the element. You cant mess it up if you have the right two wires. What wires do you have and the colors. Can they reach the element connectors. How many do you have?
Jul 27, 2011 | Dryers
Need wiring diagram for electric cord attachment
Wiring Option1: Wiring Option2: OLDER HOMES AND ELECTRIC DRYERS NEWER HOMES AND ELECTRIC DRYERS range%203-wire_cord_connection_250.jpg range%204-wire_cord_connection_250.jpg
NEMA 10-30R 30AMP-125/250VOLT
NEMA 14-30 30AMP-125/250VOLT
This system can be configured depending on what your wiring situation is.
For example you could be faced with the following situations:
converting an old 3-wire outlet
to a new electric dryer
converting a new 4-wire outlet
to an old electric dryer
Feb 01, 2011 | Amana ALE643RB Electric Dryer
Blowing high limit fuses
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Feb 22, 2009 | Amana ALE230RAW Electric Dryer
LEA30AW AMANA DRYER TIMER SWITCH CONNECTION PROBLEM..
I don't have a diagram but it is possible the the first letter of many of the colors is on the plastic around the screw connectors. Have a look. Good luck.
Dec 21, 2007 | Amana DLE330RAW Electric Dryer
Replacing a pigtail
Sep 19, 2007 | Amana DLE330RAW Electric Dryer
Amana NDE2335AY Electric Dryer Logo
332 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
