Question about Akai Televison & Video
I have an Akai AT-A102 tuner and do not have an owner's manual. I particular I am interested in how to lock the radio stations into the programable ports(?)
  • Anonymous Mar 21, 2014
    How do I pre-set radio frequencies?
I had the same problem this week, but I have found it.
Push the up or down button for the asked frequenty.
Push memory, ounce for port 1-8, twice for 9-16.
On the display you see "memo" lightning.
During this time push the port you need.
Greetings, Lubeek, Holland
Posted on Aug 06, 2010
  • Gail Aug 24, 2013
    Thank you very much!!!!!!!!
    New Friend:
I did just what you said and it worked. Although I did have to figure out a few of your words. :) But that's ok. Do you know how to get the surround sound to work on an akai DHT 300? It has a dvd receiver and only 1 speaker will hook up?
Posted on Aug 24, 2013
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
M&s 602 radio tuner seems stuck cannot pick up any other channel than 89.1 Hispanic.
If the tuner has a search mode and that mode has been selected it will lock on 89.1 MHz continually because it is the strongrest station in your area. The solution is to tune manually to program your stations
Sep 29, 2012 | Lands Phones
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
I knave a teac model ex cd3. Have lost the manual. Can't remember how to reset the radio stations. Can you help?
OK press power on,select tuner button for radio. then select band AM or FM. Then press tuning mode button until you see [manual] in the window. then press the tuning button [arrow left or arrow right buttons] until you get to your desired station.then press program / memory set. a memory number will flash [ say memory 1]. then press program/ memory /set button again to lock in the selection [memory 1] now this is the TRICKY PART. Once the selection is memorized go back to tuning mode Press the tuning mode button until you see manual and i think you can follow the above procedure. If you program AM stations first Then press the BAND button to get FM stations and go back to step one.
Feb 17, 2011 | Teac EX-CD3 CD Shelf System
HOW DO I CHANGE THE DATE ON MY SHARP XE-A102 CASH
this link has the entire manual down load
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/XE-A102-_E
it is located on page 2 number 5 under basic programming!
Jul 27, 2010 | Computers & Internet
LG LX-M240 operating instructions: I cannot set the presets
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Stations on presets 1, 2 and 3 take longer to 'kick in' when listening to the radio
as they are the 'tens' prefix for the preset numbers. 4 - 9 'kick in' immediately.
Jul 01, 2009 | LG Audio Players & Recorders
How do I preset radio stations on my hi-fi system?
On pg13
Apr 28, 2009 | Denon DRA-375RD Receiver
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Televison & Video Logo
399 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
