Question about 3Com Switch 4210 (3CR17334-91-US)
I have an HP 4210 26 port switch. I am trying to add the default vlan 1 and vlan 39 to ports 24 and 25, tagged. When I do I cannot access the unit.
3 Suggested Answers
fredi_utah
  • 3 Answers
SOURCE: Switch 2950 24 ports with problems
yellow light on ports means the port is not working or was shutdown due to port security
Posted on Nov 27, 2008
AbhiRay
  • 124 Answers
SOURCE: Sir I have 4200 series
If you are creating only Layer 2 VLANs on the switch , you wont be able to ping the servers and Routers as they are in default VLAN1.
you can do the below steps
1. Create sub interfaces on the router LAN interface
2. Provide a new ip range to the new sub interface
3. Make the switch port connecting router as trunk, so that it will carry both the VLAN info
4. on your Labtop/PC give the IP address in the newly defined range
5. Make your switch port to be in the new VLAN
This will work , if you wont be able to configure the above settings, let me know i will give you the detailed config
Posted on Nov 01, 2010
How Do I Restore the Default VLAN Configuration of an Interface?
We can take S5700-28P-PWR-LI-AC as example.
The default VLAN configuration of an interface involves the default VLAN of the interface and the VLAN that the interface joins. By default, the default VLAN configuration of an interface is as follows:
Access: The default VLAN is VLAN 1, and an access interface joins VLAN 1 in untagged mode.
Trunk: The default VLAN is VLAN 1, and a trunk interface joins VLAN 1 to VLAN 4094 in tagged mode. That is, a trunk interface allows all VLANs.
Hybrid: The default VLAN is VLAN 1, and a hybrid interface joins VLAN 1 in untagged mode.
Dot1q-tunnel: The default VLAN is VLAN 1, and an dot1q-tunnel interface joins VLAN .1
Negotiation-auto or Negotiation-desirable: If the interface is negotiated as an access interface, the default VLAN configuration of the interface is the same as that of the access interface. If the interface is negotiated as a trunk interface, the default VLAN is VLAN 1 and the interface joins VLANs 1 to 4094 in tagged mode. That is, the interface allows all VLANs.
Run the display this include-default ' include link-type command in the interface view to check the link type of the interface, and then perform one of the following configurations to restore the default configuration of the interface.
Restore the default VLAN configuration of an access or dot1q-tunnel interface.
<HUAWEI> system-view
[HUAWEI] interface gigabitethernet 0/0/1
[HUAWEI-GigabitEthernet0/0/1] undo port default vlan
Restore the default VLAN configuration of a trunk interface.
[HUAWEI-GigabitEthernet0/0/1] undo port trunk pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port trunk allow-pass vlan all
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan 1
Restore the default VLAN configuration of a hybrid interface.
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid vlan all
[HUAWEI-GigabitEthernet0/0/1] port hybrid untagged vlan 1
Restore the default VLAN configuration of the Negotiation-auto or Negotiation-desirable interface.
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan all
Jun 28, 2016 | Compex PS2216 16Port 10100Mbps Smart...
Why Is the VLAN Priority Configured on the S5700 Invalid?
Fault Symptom The outbound interface of the switch joins a VLAN in untagged mode. When the remark 802.1p command is configured on the outbound interface, the configuration is invalid.
Cause Analysis The configuration of the S5700(such as S5700-28P-LI-AC)is as follows:
traffic classifier test
if-match any
traffic behavior test
remark 8021p 2
traffic policy test
classifier test behavior test
interface GigabitEthernet1/0/1
port link-type access
port default vlan 10
traffic-policy test outbound
The outbound interface joins a VLAN in untagged mode, so VLAN tags are removed from packets sent by the interface.
Conclusion To apply traffic policy defining remark vlan to the outbound interface, ensure that the interface joins a VLAN in tagged mode.
Jun 22, 2016 | Electrical Supplies
How to configure VLANS and Tagging
https://m.youtube.com/watch?v=krE16IRIHw4
Watch this video for switch port access . You will need to be in global config interface mode.
Jun 05, 2016 | HP ProCurve Computers & Internet
I'm trying to setup vlan 1 for data and vlan2 for voice. help please...
This depends on what the devices are doing with VLAN tagging. In the switch settings you will want to add VLAN2 and make sure you set it to Fixed on the ports you want to allow VLAN2 to work on. VLAN1 is already configured for all ports.
If your devices are tagging the VLAN2 traffic but not the VLAN1 traffic you don't need to do anything. By default any incoming non-tagged traffic will be set to VLAN1. This is because the PVID is set to 1 by default. If you need the incoming traffic to be tagged with VLAN2 changed the ports PVID to 2.
Sep 13, 2013 | Zyxel ES-2108 8PORT 10/100BT MAN L2 SWITCH...
Vlan trunk on summit 24e2
Extreme uses tagged and I untagged instead of trunk/access, so it would look like this for a trunk:
conf vlan test add port gi1 tagged
(and of course you could put other VLAN's on this same port too since it's a trunk)
conf vlan user1 add port gi1 tagged
and this for handoff:
conf vlan lam test add port fa1 untagged
Feb 14, 2012 | Extreme Networks Summit 24e2 Networking...
Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
Cisco error on switch
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Feb 06, 2008 | Cisco Catalyst 4006 Chassis ( 4006)
3Com Switch 4210 (3CR17334-91-US) Logo
108 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
