Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
The wireless light is flashing red..what does this mean?
Everything was set up and going good with the wireless router. Then someone else came in with a laptop and typed in the security code to get wireless in the house...then the original laptop in the house was not able to connect to the internet at all but the second laptop that connected in WAS able to get wireless here. What is the problem and how can it be fixed??
  • 708 Answers
The Problem is this :: "Wifi protected setup on the router is Enabled "
Connect Router - Computer (Wired)
Open router Setup by typing http://192.168.2.1 on the address bar of your web browser (Internet Explorer)
On the left under wireless Click Wi - Fi Protected Setup (WPS)
leave the password Blank And click Submit
Disable it and click apply changes
On the left under wireless click security
Select the Security mode as WPA
Type the password that you want in the blank box for pre shared key (PSK)
Click Apply changes
On the left under wireless click channel and SSID
Change the channel to 6 , Change the SSID to a different name ( Make sure it is not the name that you used before)
Click apply changes
Unplug the Power cord from the router
Restart the computer
Plug the Power Cord back to the Router
Now try to connect to the new network you just setup
Posted on Aug 01, 2010
Tip
How to connect to Xbox Live wirelessly
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
on Jan 25, 2010 | Video Game Consoles & Games
Trying to connect to x box live. just bought the
Okay so here we go!
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
Jan 18, 2010 | Microsoft Wireless Network Adapter Xbox...
How do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay so here we go!
Jan 16, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox live on netopia router
Okay so here we go!
Jan 10, 2010 | Netopia 2247NWG-VGx Wireless Router...
How can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay so here we go!
Hope this tip helps :).
Dec 31, 2009 | Microsoft Wireless Network Adapter Xbox...
Need help connecting xbox live to the internet, have the wireless router but nothing is successful
Okay so here we go!
Dec 29, 2009 | Microsoft Xbox 360 Console
I just bought xbox live wireless and i have a westell 6100 router
Okay so here we go!
Dec 28, 2009 | Westell Wirespeed ProLine 6100 Router...
Having problems hucking up to xbox live
Okay so here we go!
Dec 25, 2009 | Microsoft Wireless Network Adapter Xbox...
Light stays red
A red steady light on the adapter means it is ready to be connected to a wireless network.
So you need to take note of the SSID (wireless network name) and the Wireless security settings (WEP, WPA passphrase) from the wireless access point/router.
Once you have the wireless network settings on the access-point/router, go to the System area to enter those settings.
If all settings are correct, exit the System area. Your console should now be connected to your wireless network.
Hope this helps! Good luck!
Dec 09, 2009 | Microsoft Wireless Network Adapter Xbox...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
229 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
