Question about Whirlpool Washing Machines
My washer keeps reading F 02 and beeps. - Whirlpool Washing Machines
    President:
  • 1,382 Answers
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Posted on Jul 30, 2010
Washer is flashing a signal of 02 F and beeping
F02:
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps stopping and beeping 02 F....
F02 indicates it is either draining too slowly or not at all. 1) Remove the bottom panel. 2) The pump access cover is in the centre. You can remove this to see if it is clogged. Keep in mind that when you remove this cover all the water in the machine is going to come out. 3) If the pump isn't clogged then you may need to replace the pump assembly.
Jan 14, 2011 | Kenmore Elite 45986 Front Load Washer
Washing machine keeps stoppping.
Hi just read your posting.Now when the machine starts to beep it will show a series of lights.These lights will be in a row of 8 lights.Starting from the left to right which ones are lit when the machine is beeping?Is it the 2nd and 5th or the 4th and 7th ---etc---?Please reply with additional information and I can help you further.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
My front load washer keeps beeping even when there
Beeping is pretty vague, but here it goes. Read the very broad answer. Your answer will be in it. I hope this helps.
LOOK HERE
May 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
My washer keeps beeping f02 at me
Hi There
I have found the code that you are looking for and i hope this helps you. Let me know how it goes.
F/02 Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank you for writing to fix ya.
Best Regards Richard
Mar 22, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Beep will load is running
This sounds like the same problem I had. It turned out to be a loose solder joint on the potentiometer for the water level. A few minutes with a soldering iron and it was fixed. I'm not an appliance tech but as near as I can tell, any input from any button or knob will turn the machine on and/or create a beep. Therefore, a loose connection at various places on this board could cause the same problem. I have also read about a lot of control board problems with various kenmore appliances. I suspect many of them may have a similar cause. Hope this helps.
Mar 19, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
No Spin
Hey, I know it's probably late, but I'm having a similar problem in that it's not spinning and I'm getting an error message of F 02. Did you have this problem? How did you fix yours? Please let me know, I need to wash clothes for my son's prom tonight. Thanks.
Oct 20, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
19 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
