Question about Garmin nuvi 265 Car GPS Receiver
When i power on, the device's touch screen does not seem to work
  • paterin Jul 30, 2010
    yes but touch screen is not responsive
  • 268 Answers
Ok so ur touch needs calibration, here is how u can do it,
Turn the nuvi off and then back on. Slide the power key to the right(lock). Hold your finger on the screen for about 30 seconds until the calibration screen appears. Follow the on-screen instructions.
Posted on Jul 30, 2010
Cannot access htc phone with touch screen not working
Touch screen XYZ access has degenerated and is dysfunctional. Only a technical service representative can assist you in fixing the device.
Feb 26, 2014 | HTC EVO 4G Sprint - /
LA PANTALLA TACTIL NO FUNCIONA
google translated
TOUCH SCREEN NOT WORKING
DO NOT OPERATE AS TOUCH PANTLLA
Touchscreen computers and handheld devices are the newest wave of technological gadgets as of 2010. While these devices function impressively, they can malfunction just like any other technical device. Troubleshooting the touchscreen is simple and often will correct any issues.
Identify how the screen is behaving. A touchscreen will malfunction in one of two areas--sensitivity or position. If you touch the screen and the cursor is not centered on your finger, this is a position error and requires recalibration of the screen. If you touch the screen and it does not register your touch without pressing hard, this is a sensitivity error. If you touch the screen and nothing happens, this can be a sensitivity error or a malfunctioning screen. Calibrate the screen. For all main errors, calibrating the screen will correct the issue. Every device has a different method of calibration but can usually be found under a "Tools" or "Diagnostics" menu option. Reload the device. For handheld devices, remove the battery and let the device rest for no less than five minutes. For computer or computer system devices, power down the device, disconnect the touchscreen device from the computer and remove any power cords to it. Allow the device to rest for five minutes. Reattach the device or reinstall the battery and power up the device. If issues persist, reload the software for the device. For handheld devices, do a full wipe of the device and return it to factory specifications. For add-on devices to a computer or computer system, uninstall the device and reinstall the drivers. If reloading, registering or calibrating the device does not work, consult the manufacturer for possible warranty replacement options.
Feb 26, 2013 | Computers & Internet
LG KS20 touch screen not responding corecttly some times.
LG KS20 touch screen SolutionGo to settings menu - Touch celebration - click correctly touch position - u see done.
or" change your PDA ( touch screen )
Dec 15, 2011 | LG KS20 Smartphone
Screen seems OK but there is no way to interface as it does not respond to touch. Unit is 255w and about 2 years old.
The solution to this problem is for you to calibrate the screen. Before calibrating the screen, i will advice you reset the gps. To reset your device, hold down the power button for about 15 seconds, it will restart itself and power up fully, if the touch screen does not still work, then calibrating the screen will do the job for you. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Hold the upper left corner of the screen, then turn on the nuvi,
  3. Release the power key once the garmin screen appears,
  4. Continue to hold the upper left corner of the screen for 30 seconds till a white screen with 'touch dots' appears,
  5. Then follow the rest of the guide from there.
It might take a few tries before it works for you but you have to keep trying till you get it right. I am very certain that this will work for you.
Dec 31, 2010 | Garmin nuvi 255W GPS Receiver
Screen on my Garmin Nuvi 650 is frozen (no reaction to touch). Cna move through screens via the on/off button. Haven't updated maps...ever. Seems like most repairs will cost me $25 just in shipping. ...
The problem with the gps device is a minor one. First you ensure it is properly charged, then you reset it by holding down the power button for about 15 seconds, then it will restart and you will be able to touch the screen once again. If that does not work, then you need to calibrate the screen, take note that calibrating the screen does not just work the moment you try it, you need to try it repeatedly till you get it right. This is how to calibrate your nuvi:
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen for about 30 seconds until the calibration screen comes appears (white screen with touch dot),
  4. Follow the on screen instructions.
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
Dec 28, 2010 | Garmin Nuvi 660 GPS Receiver
My touch screen will not function. It seems to start okay but the touch screen wont work from that point. I have reset. Garmin NUVI
Turn off the device.
Press and hold the upper-left corner of the screen and turn the power on.
Keep holding the screen and release the power button when the screen is on. Keep holding the screen for next 30 secs and u will see a "press button" on the screen.
at that point release the screen from upper-left corner and touch the press black point on the screen to calibarate it.
should be fine after that.
thanks
Jul 29, 2010 | Garmin Nuvi 660 GPS Receiver
Magellan Maestro 3140 touch screen alignment
I have the same problem. It seems the only answer is to purchase another GPS. I am looking at the Garmin 765T
Jan 05, 2010 | Magellan Maestro 3140 GPS Devices
My Garmin nuvi 205W was working fine but I wanted to update it on the computer before a family trip. Update seemed to work fine but the unit would not turn back on afterwards - not in the car, by USB, or...
Have you tried a master reset??
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Nov 24, 2009 | Garmin nuvi 205W GPS Receiver
660 touchscreen doesn't detect touching
Yes, the touchscreen is defective. Please see this link for more info on this probem:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 08, 2009 | Garmin Nuvi 660 GPS Receiver
Touch screen failed after I added external antenna
have you tried resetting it (press and hold find, the press power)
Dec 04, 2007 | Garmin StreetPilot 2720 GPS Receiver
Garmin nuvi 265 Car GPS Receiver Logo
329 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
