Question about DeLonghi ® Combi CoffeeEspresso Maker
Coffee maker wont start
When i turn the machine on, the lights go on but nothing else happens? It is a delonghi model# bco-120t. do you know where i can find a wiring diagram?
I had the exact same problem with my DeLonghi Caffe Verona Expresso Machine (very old) and I replaced the thermal fuse and Bingo....it works fine! I did call DeLonghi and the tech told me the Thermal Fuse is the most common problem of no power. (providing your unit is plugged in and the receptacle works) In my unit the fuse is on top (only one) and it did have a plastic sleeve over it. The fuse was bought at Radio Shack for 1.99 and I had to solder it on because I forgot to get the little crimp ends from the Radio Shack guy. oops If I can do it...anybody can. (55 year old Grandma)
Posted on Apr 08, 2011
    Problem Solver:
  • 5 Answers
There are thermal fuses on the bottom. You must remove the bottom cover to see them under the heating tray. If the heating does not work the water will not heat and rise (no drip - nada). I posted some pics on my ebay store.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150370700440&ssPageName=STRK:MESE:IT
I am not a Coffee Machine technician, I am a computer technician who can troubleshoot to the electronic component level. I understand that some of my comments may not be correct so keep your negative comments to yourself. This worked for me on many Coffee Machines that I had to resell. Just sharing the love. Thank you.
TYPICAL FAILURE OF THIS MACHINE = THERMAL FUSE MALFUNCTION.
WHERE ARE THE THERMAL FUSES: There are 2 thermal fuses under the coffe tray and 1 fuse under the espresso boiler. (YOU WILL HAVE TO REMOVE THE BOTTOM COVER OF THE MACHINE). What this fuse does is regulate the temperature of the heating element so that everything doesn't melt (yep, I tried to bypass the fuse and found out the hard way..testing...testing..). Anyway, replacement for these thermal fuses are sold at RADIO SHACK for about $2.00. (Yep, only $2.00) If you open the bottom cover of the coffee maker and you will see the 2 fuses, they look like resistors. they are covered in a plastic tube to prevent damage. Clip them off I used a small wrench(radio shack) to pry open the small clamps that hold them, replaced them, then reclamped the new fuse back on.
REPLACEMENT FUSES: The thermal fuses have the watts/Amps and temperature stamped on them. There is 1 part that I use and has been working well for over a year ( over a year, yes this machine can last a long time!!).
The part # is Labeled - Raido Shack 270-1321 Thermal Fuse 438°F (226°C) 250VAC 10A (For heating devices like coffee makers and hair dryers). The temperature may vary + - a few degrees° on the label, from what I have seen.
HOW TO TEST THERMAL FUSES: These fuses are not only used for temp control but they also close the curcuit. If the fuse blows then it is open and will not heat. I use my ohmeter (put 1 prong at each end of the fuse) and if it reads open it means that the thermal fuse is bad, it has blown, there is no current running through it. I believe a light meter can check for continuity also and are much cheaper. Test by putting the test leads at each end of the fuse (1 prong at each end).If the light turns on then you are good, getting continuity. If you cannot get no light then it is bad. You can test your light fuse with a simple wire, touch each end and the light should go on, cut the wire in the middle and no light!!easy.
fyi. If your coffee does not get hot enough the fuse may need to be replaced also.
HOW TO READ THE OHMETER.
Know that a reading of OL means "over limit." That means the resistance is off the charts, and you have a break in the circuit. If you got an OL reading for the plug wires, you'd know there was a broken wire that needs replacing. In this case, we got an OL reading because the light switch is in the "OFF" position.
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwX1LcJD
Consider that a low reading, anywhere from 0 to .5, indicates very little to no resistance. This means there's a continuity of current in the circuit. This is the reading you should get
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwXjz6C0
Posted on Sep 30, 2010
  • turks42 Mar 12, 2011
    This sounds like the right solution; problem is, there is some rather unusual hardware (think small hexhead, only with a pin protruding from the center) attaching the bottom plate to the unit, which clearly requires a specialized tool. Any ideas where to get one?
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
How obtained A download a manual?
Go to this site to get a manual. It is listed under CUSTOMER SUPPORT. :-) Here is the link to the website. http://www.delonghi.com/en-us/products/coffee-and-espresso/coffee-makers/nespresso-system/lattissima-pro-en-750mb-0132192224?gclid=Cj0KEQjwrqieBRCln82Rgufz7I0BEiQAPNjAIwPVQ5e68guS8rRE8O_Lry_tcDMQOapRV2KTlEHJuIkaAqS_8P8HAQ Lattissima Pro EN 750 MB
Jul 20, 2014 | DeLonghi Coffee Makers & Espresso Machines
Lifetime of BCO 130
when did you last descale the unit?
also running Milton fluid to the correct strength through with out heating may kill any bugs
Dec 06, 2013 | DeLonghi Coffee Makers & Espresso Machines
We havn't had our Delonghi BCO-120T but for 3 months & the coffee side stopped working all together. My husband is a great handyman & after taking that side apart. the tubing & tank looks...
In uk delonghi spares by agents of kenwood.co.uk. there is a directory of local agents. before ordering element check thermal fuse attached to the element it may be open circuit.
Jul 29, 2010 | DeLonghi BCO120T Programmable Espresso /...
I bought a replacement water filer for my DeLonghi BC070 coffee machine. Where does it go?
The model number you posted does not work to find the manual, so go to there website I posted below and find your manual, because one of the models that is close to your shows the filter inside the top that you remove, and it has some nice pictures of how to replace it, so go here and find your, sorry I could not be anymore help.
At the top left side it says search key word or product model, type in your exact model- like BCO-130t,
http://www.delonghiusa.com/index.php?products&catid=1
I posted a live link, so just click on it and there website will open.
Feb 12, 2010 | DeLonghi Caffe Nabucco BCO70...
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
Jul 03, 2009 | DeLonghi DCM485 Coffee Maker
My water tank is leking
Use M-Seal paste, this will stop all leking ( it should be apply in dry mode)
Jul 03, 2009 | DeLonghi BCO 130 Espresso Machine & Coffee...
DeLonghi ® Combi CoffeeEspresso Maker Logo
1,149 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
