-   three red lights just started flashing and went to website and found how to get codes to see whats wrong and the codes says the xbox doesnt really know what is wrong. it says that there is a short or cold solder or something what can i do with this?-   jaishon
Jan 16, 2009
-   three flashing red lights, the upper right quadrant light is not flashing, what do i do-   Guest
Jul 27, 2008
-   dt_lineup_23
Apr 24, 2008
-   we have tried many things but nothing works-   moises1996
When someone say that his/her Xbox is having 3 red lights Flashing problem, It means it needs to be repaired. If you are using Cooler than
it is not a cure but a prevention. You could have used cooler before
acutally having the problem just to prevent your Xbox. But now you will
have to either get it repaired from Microsoft (in case your Xbox's
warranty is not expired, but one thing to note is that you will have to
wait for at least 3-4 weeks to get back your Xbox) or you can Fix your
Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
If your symptom is : Three lights on the Ring of Light flashing red on the front of your Xbox 360 console.
The upper-right quadrant light is the only light that does not flash red.
then you have a hardware fault of some sort and it will be most likely that Microsoft (or the store you bought it from) will need to look at it for warranty work. If it is not under warranty any more you will need to find someone who does repairs on xboxs to look at it for you.
Microsoft have some info on their website in case you wanted to view: http://support.microsoft.com/kb/907534
Just got xbox in the mail, hooked up to tv and can't get it to work, when hooking up and you havce...
(More)
Just got xbox in the mail, hooked up to tv and can't get it to work, when hooking up and you havce dish network, is there something different you need to do? Thanks, dww
just got my xbox back from factory, they gave me a new one and now it says i need a memory unit to...
(More)
just got my xbox back from factory, they gave me a new one and now it says i need a memory unit to make a profile
the xbox 360 connects with the controller (wireless) when it wants to and when it does it only works...
(More)
the xbox 360 connects with the controller (wireless) when it wants to and when it does it only works for like 5 minutes. I tried using a wired controller and it does not work either. what can I do to fix it?
