Question about Microsoft Xbox 360 Console
3 flashing red lights on xbox 360 - Microsoft Xbox 360 Console
  • 10,319 Answers
Check out the link below to find out the problem on your x box
http://support.xbox.com/support/en/us/nxe/kb.aspx?category=hardware&ID=907534&lcid=1033
Posted on Jul 30, 2010
  • frank thomas wilson
    frank thomas wilson Jul 30, 2010
    I do hope you had found out what the problem was
SOURCE: fix xbox 360
the famous red ring of death caused by overheating stick a fan behind it!
Posted on Jul 15, 2008
  • 16 Answers
SOURCE: 2 red lights xbox 360
hardware problem... when it over heated it must of melted somthing in it... mine did that too
Posted on Apr 06, 2009
FixMyConsole
  • 174 Answers
SOURCE: i have one red light on my xbox 360 that is flashing
1 red light usually means a graphics chip problem. A reflow of the graphics processor usually solves this.
Give us a call / shout if you need any assistance.
FixMyConsole
Posted on May 25, 2009
  • 1093 Answers
SOURCE: XBOX 360 TWO RED LIGHTS FLASH
2 red lights is overheating and to get it fixed you will have to send it back to Microsoft and the waiting time is painful at 4 weeks, if you don't want to do this then you should fix it yourself using a good guide at home
Posted on Sep 21, 2009
localwonder
  • 6784 Answers
SOURCE: my xbox 360 has shown up one red flashing light and E73
HI. This is an Ethernet port issue.
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try using a new Ethernet cord. If the error continues after the new cord is used, contact Microsoft for a repair ticket. the port will need to be replaced. (Internal connection failure)
Possible solder break
Posted on Oct 13, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
RED RING WHEN TURNED ON OFF FOR A WEEK
Nov 26, 2008 | Microsoft Xbox 360 Console
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Sep 05, 2008 | Video Game Consoles & Games
Flashing 3 red lights
The 3 flashing lights suggests that it's a hardware problem and you'll have to send your 360 to Microsoft for repair. Go on xbox.com and there is a link for repairs.
May 26, 2008 | Microsoft Xbox 360 Console
Xbox 360
Hello simmaz,
I flashing red light may mean you have an hardware failure. Here is a link to Microsoft support for the Xbox 360.
http://support.microsoft.com/kb/907536
I hope this helps.
Sincerely,
Agent Xiong
Apr 27, 2008 | Microsoft Xbox 360 Console
4 red lights
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
